 Wheel bearings
2 posters
hmac
hmac
Wheel bearings Empty
PostSubject: Wheel bearings   Wheel bearings Icon_minitimeTue Apr 05, 2016 12:59 pm
While I had my rear wheel off my VZ800 I noticed the bearings were a bit rough. Has anyone changed them? Is it just a case of knocking the bearing out from the opposite side or does it require special tools?
PostSubject: Re: Wheel bearings   Wheel bearings Icon_minitimeTue Apr 05, 2016 2:43 pm
Nah dead easy Harry, carefully knock out from opposite side, & remember if any spacers came out as well & which side.
Clean out the old grease, there won't be much believe me! I put some extra grease into the bearing as they also don't have much in them & then put into the freezer overnight.
Put some fresh grease into the hub centre & put one bearing in first, then the centre tube & any spacers obviously & then tap in the other bearing with a soft hammer & when you think they're fully home use a soft punch to finally tap home the bearings on both sides, never use a punch or hammer on the inner race as you will destroy the bearing before you start!
Most important thing is to keep everything clean as you go even down to cleaning the wheel hub itself before you take the old bearings out. BTW some folk warm up the hub before you take the bearings out & also put them back but I've only had to resort to this action once when the bearings were literally rusted into the hub!
Oh & some manufacturers put rubber shields into both sides of the bearing. I carefully prise the seal out on one sideĀ  & put more grease into the bearing because as I said they don't put much grease into the bearings when they make the things & then if I can I put the shield back in again.
hmac
hmac
PostSubject: Re: Wheel bearings   Wheel bearings Icon_minitimeWed Apr 06, 2016 12:01 am
Thanks peter, pulled the rear wheel out and noticed the spacer tube inside the hub. Pushed it to the side and tapped the bearings out with an old screw driver and a hammer. Will tap the new bearings in tomorrow.
PostSubject: Re: Wheel bearings   Wheel bearings Icon_minitimeWed Apr 06, 2016 2:08 pm
Harry don't overdo the grease ok as it will find it's way out so just a bit ok not half a tub's worth lol!
Wheel bearings
» Front wheel gap?
» wheel conversion
» Straight handlebars for Suzuki M800
» front wheel
» VL 800 Rear wheel removal
Wheel bearings Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Wheel bearings Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Wheel bearings Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Wheel bearings Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Wheel bearings Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Wheel bearings Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Wheel bearings Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Wheel bearings Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Wheel bearings Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Wheel bearings Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Wheel bearings Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Wheel bearings Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Wheel bearings Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Wheel bearings Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Wheel bearings Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Wheel bearings Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Wheel bearings Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Wheel bearings Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Wheel bearings Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Wheel bearings Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
