 Fitting additional on/off light switch
4 posters
NZGlyn
Fitting additional on/off light switch  Empty
PostSubject: Fitting additional on/off light switch    Fitting additional on/off light switch  Icon_minitimeWed Feb 07, 2018 6:32 pm
I have a VX 800 and the lights are wired to be on all of the time. I've always liked to start my bikes with lights off and then put them on when starting off. Has anyone fitted a separate switch to enable this to be done and where would be the best place to splice into the wiring loom?  Cheers Glyn.
PostSubject: Re: Fitting additional on/off light switch    Fitting additional on/off light switch  Icon_minitimeWed Feb 07, 2018 7:47 pm
hmac
hmac
PostSubject: Re: Fitting additional on/off light switch    Fitting additional on/off light switch  Icon_minitimeThu Feb 08, 2018 9:24 am
Does your bike not have a relay that switches the headlight off automatically when you press the starter button?
NZGlyn
PostSubject: Re: Fitting additional on/off light switch    Fitting additional on/off light switch  Icon_minitimeThu Feb 08, 2018 10:00 am
Not that I have seen or am aware of. I will check next time I start it however. I still would like to have control over the light however.
PostSubject: Re: Fitting additional on/off light switch    Fitting additional on/off light switch  Icon_minitimeFri Feb 09, 2018 7:49 am
You do not need to splice into the loom, the UK version of the bike had a light switch, so you could just replace the switch on yours. Looking at the wiring schematic, the loom is the same on both bikes, it just looks like a couple of links in the connector where your switch plugs in.
UK
Fitting additional on/off light switch  Uk_vx10
Yours
Fitting additional on/off light switch  Nz_vx11
» My brake light works, but my tail light does not function..
» water temp light and ignition light
»  New LED Rear Light & Break Light Idea
» Extended additional cablel question for sparkies
» Fitting of swing arm
Fitting additional on/off light switch  Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Fitting additional on/off light switch  Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Fitting additional on/off light switch  Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Fitting additional on/off light switch  Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Fitting additional on/off light switch  Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Fitting additional on/off light switch  Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Fitting additional on/off light switch  Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Fitting additional on/off light switch  Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Fitting additional on/off light switch  Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Fitting additional on/off light switch  Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Fitting additional on/off light switch  Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Fitting additional on/off light switch  Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Fitting additional on/off light switch  Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Fitting additional on/off light switch  Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Fitting additional on/off light switch  Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Fitting additional on/off light switch  Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Fitting additional on/off light switch  Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Fitting additional on/off light switch  Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Fitting additional on/off light switch  Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Fitting additional on/off light switch  Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
