 Wider tires
4 posters
jan1
jan1
Wider tires Empty
PostSubject: Wider tires   Wider tires Icon_minitimeThu Apr 12, 2018 9:50 am
Hello ! So here goes my first topic.
I'd like to put on wider tires on my VZ bobber. Especially the rear. Today i have the stock 170/80-15 Rear and 130/90-16 Front.
What are my options ?
Jan
captain morgan
Wider tires Empty
PostSubject: Re: Wider tires   Wider tires Icon_minitimeThu Apr 12, 2018 6:21 pm
Options are what ever you want mate front end I'm guessing normally is change your yokes to wider ones then your forks will take a wider front wheel just a thought but I wonder what size front wheel a vz 1500cc has? or the VZR 1800 but basically any yoke/triple tree that has the same size bolt to fit your frame will work but the yokes might need forks with  a larger diameter the triple tree could come from any bike I suppose?? hopefully someone else will give you an answer I would imagine the best or maybe cheapest place to get bit's is of eBay as they tend to brake a lot of bikes and sell all the parts on there.
As far as the rear end goes there is a member on this site that has done that
captain morgan
Wider tires Empty
PS
sorry I cant be of any real help
Wider tires Empty
PostSubject: Re: Wider tires   Wider tires Icon_minitimeThu Apr 12, 2018 11:15 pm
Pretty sure you can go up 10mm on each tyre/tire without anything rubbing or catching, ie, 180 rear and 140 front (not sure there is a 140 made though?)  have a look through the forum, It's been asked and done before  Wider tires 3498837457
Wider tires Empty
PostSubject: Re: Wider tires   Wider tires Icon_minitimeFri Apr 13, 2018 5:53 am
The 800 handles pretty neat. Wider rear tyres on customs usually means cool and better in straight lines. The cornering may not be so good. Your choice. In truth slightly bigger rear won't make much difference visually or practically. Go really big for impact (240?  Wider tires 2037161312) but you will need a larger wheel and other mods. I'm pretty sure it's been done on here. Try a search. Good luck! Someone told me 16" bars were too tall but I did it anyway and loved the result! Cost is the only real obstacle to modifying your motorcycle! Added value returns will be lower than your personal pleasure.
Wider tires Empty
Wider tires
» tires
» New Tires
» Wider Rar Tire 200/70R15
» Wider Angle Mirror Upgrade
» vx 800 changing tires - lowering the rpms getting a totally new bike
Wider tires Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Wider tires Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Wider tires Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Wider tires Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Wider tires Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Wider tires Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Wider tires Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Wider tires Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Wider tires Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Wider tires Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Wider tires Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Wider tires Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Wider tires Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Wider tires Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Wider tires Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Wider tires Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Wider tires Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Wider tires Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Wider tires Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Wider tires Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
