when i try to check my oil level i look in the little window by the brake pedal. unfortunatly the little sight glass is black. does this mean my oil is full ot the glass is dirty? it runs fine and the doesnt leak so what can i do short of draining it a refilling
Sounds like the engine is over full & you can't see the proper level. If I were you it would be changed for new oil + a filter so you know exactly what the engine should be reading etc.....?
Sounds like your VX is overfull of oil ...... ..... but I presume you are reading it with the bike on the main stand on level ground.
As Peter says, if the oil is 'dirty looking' and you don't know when it was last changed (Time or mileage) then it would be wise to treat your bike to new engine oil & filter.
Hope you're enjoying your VX
Yam
BudPotter Prospect
Subject: Re: VX 800 Oil level Tue Aug 07, 2018 5:48 am
oil changed and choke cable fixed as well as bunch of sketchy electrical connections. This is one cool bike and i love it
