 VZ800 Charging issue
2 posters
brownsjuk67
VZ800 Charging issue Empty
PostSubject: VZ800 Charging issue   VZ800 Charging issue Icon_minitimeMon Jun 03, 2019 9:59 am
Morning Folks
I purchased a 1999 VZ800 as a project bike with issues which I'm working through. One of the issues is with the charging system on this bike. With the bike running I'm only reading 12V across the battery terminals and this does not increase when I rev the bike.
This looked like a typical regulator rectifier failure so new reg was purchased and fitted but the output voltage remained the same. I sent this back to the vendor as a faulty item and they replaced it but eve after this was fitted the same issue remained.
What seems to be happening is that when I start the bike the regulator output is around 13.5V but this quickly reduces to 12-12.5V. All three phases from the stator seem to be emitting a good voltage and all the wiring has tested good but I'm stumped. Am I missing something? Thanks Steve.
PostSubject: Re: VZ800 Charging issue   VZ800 Charging issue Icon_minitimeMon Jun 03, 2019 2:03 pm
Have you tried using another battery as even if it seems ok it can be breaking down ok.
brownsjuk67
PostSubject: Re: VZ800 Charging issue   VZ800 Charging issue Icon_minitimeThu Jul 18, 2019 9:18 am
Well after much investigation and unnecessarily replacing the regulator for a genuine Suzuki part at a cost of £210 I managed to get to the bottom of the charging issue on my Marauder. On the positive circuit between the regulator and the battery it passes through a 30 amp fuse which is integrated into the starter solenoid. The connector which plugs into the starter solenoid which also contains this positive charging circuit was burnt out. So I had to cut these wires out of the connector and replace the 30 amp fuse with an inline one. Job done.
» charging issue with my vl800 k8 2008 intruder
» Battery connections - charging
» Rusty Gas ank, bike stalling and what not.
» Elecrical issue
» Optimate 3 charger / battery, possible issue?
VZ800 Charging issue Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
VZ800 Charging issue Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
VZ800 Charging issue Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
VZ800 Charging issue Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
VZ800 Charging issue Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
VZ800 Charging issue Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
VZ800 Charging issue Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
VZ800 Charging issue Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
VZ800 Charging issue Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
VZ800 Charging issue Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
VZ800 Charging issue Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
VZ800 Charging issue Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
VZ800 Charging issue Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
VZ800 Charging issue Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
VZ800 Charging issue Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
VZ800 Charging issue Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
VZ800 Charging issue Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
VZ800 Charging issue Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
VZ800 Charging issue Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
VZ800 Charging issue Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
