 Battery connections - charging
6 posters
Battery connections - charging Empty
PostSubject: Battery connections - charging   Battery connections - charging Icon_minitimeSun Jan 24, 2016 2:24 pm
Hi everyone,
The c800 has been sitting idle for a few weeks! yes I know should use it as much as the orange girl machine but its just not practical when filtering through mentally heavy London traffic.
Anyway went to crank it up yesterday and the battery was ALMOST dead, luckily not dead enough to wipe the trip computers but enough so the bike would not fire up.
Undid the seats etc etc to get to battery plugged in the basic charger "ring" I think a lidl job and after 3 hours later all good.
I don't have a garage or anywhere safe where I can just plug the bikes in and leave them on optimizers, I don't want to remove the batteries as I do like to jump on them when the weather is ok and use them as much as possible so my question is....
I want to do the mod several of you have done where by a tail lead is ever present sticking out from under the seat so I can just plug in/clamp on the charger occasionally and boost the battery without having to remove the seats etc BUT my charger only has bulldog clips!
I don't mind cutting these of and replacing them with a different connector but I don't know which ones are appropriate/safe?
So what guage wire should I use as the leads from the battery + and - terminals and can you recommend connectors that are water proof and safe to use to connect from them to the charger.
Many thanks J
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeSun Jan 24, 2016 2:49 pm
Try these Justin. two different fittings!
http://www.ebay.co.uk/itm/Optimate-3-4-Dual-Program-Accumate-Charger-Waterproof-Battery-Connector-Lead-TM-/351475970842?hash=item51d599b31a
http://www.ebay.co.uk/itm/Optimate-3-4-Dual-Program-Accumate-Charger-Waterproof-Battery-Connector-Lead-SAE-/400697538206?hash=item5d4b6f369e
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeSun Jan 24, 2016 4:14 pm
Thanks john but I don't have an optimate, the charger I have has normal bulldog clips so I will need connectors that I can use to replace them.
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeSun Jan 24, 2016 4:26 pm
These are what's on the ends of my oximiser, any use?  www.ebay.co.uk/itm/Optimate-Accumate-Oximiser-Hotgrips-Battery-Charger-Connectors-1-PAIR-AK-V5-/301290504338?hash=item4626504092:g:fXcAAOSw~CRTraYH
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeSun Jan 24, 2016 4:34 pm
Have you thought about a solar charger, something like this:
http://www.ebay.co.uk/itm/12V-4-5W-Power-Solar-Panel-Trickle-Battery-Charger-Fit-Auto-Car-Boat-Motorcycle-/181963634642?hash=item2a5de0b7d2:g:o~EAAOSwJcZWcV8Z
or
http://www.ebay.co.uk/itm/Solar-Powered-Optimate-12V-Motorcycle-Scooter-Battery-Charger-Optimiser-Diagnose-/151819084392?hash=item23591f6268:g:J2gAAOSwiLdV-YoE
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeSun Jan 24, 2016 5:14 pm
Thanks Andrew I like the solar idea but it would just be something else for the local scroats around here to steal!
Thanks sim I think they are what I need, if I get stingrays optimiser connections for the bike and your connectors to replace the clips on my charger that should do the trick?
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeSun Jan 24, 2016 5:28 pm
Battery connections - charging 102087026  the solar panel idea, think I'll get one!  Battery connections - charging 184121345
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeSun Jan 24, 2016 6:13 pm
Just get a those in the link for the end of the charger Gaylord, I have a spare connector with cap that'll attach to your bike, fb me your address and I'll send it the post this week  Battery connections - charging 3498837457
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeSun Jan 24, 2016 9:29 pm
Thanks sim.
The other down side with solar is they are not protected or have a cut off, so if you leave it plugged in in will continue to charge the battery even if its full! possibly not a good thing for the battery?
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeSun Jan 24, 2016 9:35 pm
True/False?..........Before I buy!
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeSun Jan 24, 2016 9:48 pm
I leave mine plugged in all the time, it just maintains (sends pulses through or something like that) when it's fully charged, I'd have thought the solar one's would work on the same basis.
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeSun Jan 24, 2016 9:50 pm
Yeah, say's at the bottom "No risk of overcharging"
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeSun Jan 24, 2016 10:57 pm
Is that the expensive optimiser version or the cheap Chinese one too, couldn't see any safety protocols on the £15 job!
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeSun Jan 24, 2016 11:02 pm
Its no wonder to me that you can't see F*** all with the 'pea soupers' you get up there! pig love
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeSun Jan 24, 2016 11:15 pm
Just the optimiser one Battery connections - charging 3498837457  the other £15 looks  Battery connections - charging 437349  that's in the clear air up North  Laughing
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeMon Jan 25, 2016 8:15 am
That's what I said!!! and the sun is still shining down here Battery connections - charging 2343124779
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeMon Jan 25, 2016 1:12 pm
Oh well! Thats the end of that idea then  Battery connections - charging 880307
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeMon Jan 25, 2016 5:17 pm
Get the more expensive one ya tight wad! you'll be saving the planet too  pig love
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeMon Jan 25, 2016 5:53 pm
OR! get one of those £3 voltage monitors dave has and run it in line with the cheap solar cell, check once a day to see what the reading is and unplug when the battery is tapped out! genius welcm
TaurusTuga
TaurusTuga
PostSubject: Re: Battery connections - charging   Battery connections - charging Icon_minitimeMon Jan 25, 2016 10:00 pm
I have one like this:
http://www.ebay.co.uk/itm/Charger-OXFORD-Oximiser-900-GEL-MF-Acid-12V-/151800630545?hash=item235805cd11:g:4y4AAOSwRLZT18~p
for more than 7 years and it's great Battery connections - charging 3498837457
Always plugged on when i am not riding.
Worth the money i spent.
» VZ800 Charging issue
» RR/Battery second opinion
» Dead Battery
» flat battery
» Lithium Battery
Battery connections - charging Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Battery connections - charging Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Battery connections - charging Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Battery connections - charging Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Battery connections - charging Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Battery connections - charging Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Battery connections - charging Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Battery connections - charging Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Battery connections - charging Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Battery connections - charging Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Battery connections - charging Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Battery connections - charging Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Battery connections - charging Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Battery connections - charging Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Battery connections - charging Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Battery connections - charging Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Battery connections - charging Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Battery connections - charging Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Battery connections - charging Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Battery connections - charging Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
