 Sachs 800 PAIR valve removal
2 posters
RonB58
Sachs 800 PAIR valve removal Empty
PostSubject: Sachs 800 PAIR valve removal   Sachs 800 PAIR valve removal Icon_minitimeFri Feb 14, 2020 5:59 pm
Hi all,
my bike has been running rough so I decided to clean out the carbs before balancing them. I needed to replace a pilot jet in the rear carb and it behaved beautifully once I richened the mixture. The front carb was losing back pressure and causing backfires so I investigated the PAIR system. It uses an induction valve operated by vacuum from the front cylinder with the take off line on the inlet manifold. Once I removed the vacuum line from the induction valve and blocked it the bike ran like a dream, no backfire and carbs balanced perfectly.
My question is have any other Sachs owners removed this or do they know what bike it is off? It is a Denso valve operated by vacuum. I also removed the PAIR lines from the exhaust ports and fabricated two blanking plates.
I think the Suzuki 800s use a solenoid with a feed from the ECU whereas the Sachs uses a more antiquated and illogical system!
Ron
adilmon
adilmon
PostSubject: Re: Sachs 800 PAIR valve removal   Sachs 800 PAIR valve removal Icon_minitimeFri Mar 13, 2020 9:59 am
RonB58 wrote:
Hi all,
Ron
Hi Ron
I've done this on my Sachs Roadster 800. I used the PAIR blanking kit made for a VS800/VL800/VZ800 and it fit perfectly. The Valve an plumbing are in a box somewhere in case I have a pedantic MOT tester.
I cleaned out my carbs too, after my bike was sat for a while, and currently trying to unstick the from pilot screw.
These bikes have different carb settings to other suzuki 805cc engines (just look at the variety of factory setting variations for VX800 and you'll know what i mean), but I did buy a Sachs OEM workshop manual from their administrators. Most of the pics in there are from the VS800 manual, but I'll post a few pages from carb section next week.
RonB58
PostSubject: Re: Sachs 800 PAIR valve removal   Sachs 800 PAIR valve removal Icon_minitimeFri Mar 13, 2020 11:08 am
Glad to hear I'm not the only one! I had to run the rear carb richer to get the balance correct on the Carbtune. Looking forward to the pics and thanks!
Ron
» Pair valve removal kit??
» Cheap Pair Valve Removal 98 VZ800
» Removed pair valve *pic* 2000 Marauder VZ800Y
» * Pair Valve, leave it or lose it C800 / C50 / M800 / M50 / VZ800 *
» PAIR Valve Blanking Kit Recommendations Please
Sachs 800 PAIR valve removal Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Sachs 800 PAIR valve removal Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Sachs 800 PAIR valve removal Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Sachs 800 PAIR valve removal Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Sachs 800 PAIR valve removal Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Sachs 800 PAIR valve removal Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Sachs 800 PAIR valve removal Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Sachs 800 PAIR valve removal Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Sachs 800 PAIR valve removal Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Sachs 800 PAIR valve removal Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Sachs 800 PAIR valve removal Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Sachs 800 PAIR valve removal Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Sachs 800 PAIR valve removal Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Sachs 800 PAIR valve removal Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Sachs 800 PAIR valve removal Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Sachs 800 PAIR valve removal Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Sachs 800 PAIR valve removal Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Sachs 800 PAIR valve removal Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Sachs 800 PAIR valve removal Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Sachs 800 PAIR valve removal Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
