| | Cheap Pair Valve Removal 98 VZ800 | |
MacGuyverMarauder Prospect
![MacGuyverMarauder](https://2img.net/u/2611/31/42/84/avatars/2040-80.gif)
![Cheap Pair Valve Removal 98 VZ800 Empty](https://2img.net/i/empty.gif) | Subject: Cheap Pair Valve Removal 98 VZ800 Wed Aug 12, 2015 7:53 pm | |
| ![Cheap Pair Valve Removal 98 VZ800 Imag0711](https://i.servimg.com/u/f18/19/29/17/55/imag0711.jpg) Well this is exactly what it says it is. I don't like spending money on these little things I feel I can do on my own, so naturally I have some pretty crazy ideas flowing out of my head with my Marauder. I removed my PAIR Valve using only the tools necessary to remove the assembly and wire cutters to help "crimp" the ends of the tubes that connect to the Jugs. I left about an inch of space in the tube from the bolt head holes and pinched it together as closed as i could get it. Then i cleaned out all the carbon from inside the tube, dried it under heat(torch), re-cleaned with a rag, and filled the tube with JB Weld, a strong two part heat-resistant epoxy. I also used some on the tip of the crimped tube to smooth it out a little. Doesn't look as good as its $20 removal kit counterpart, but works just as well. As for the small air tube that comes from the middle carb/air line, I cut it and left about 1.5 inches of extra tube hanging off, and stuck a broken old mini-screwdriver head in the excess and put the stock clamp back on, presto! So those 3 bolt holes are your only issue now. As you can see on mine, I used the PAIR Valve box cover screws with the hex heads and they fit right in....looks kinda pretty too, the third was just a random bolt i had to find, the threads didn't match but as its only for looks and really just can't fall out, I cross threaded the bolt and snugged her right in. I know this kit was cheap, but hey, now its even cheaper. | |
| ![Go down](https://2img.net/i/empty.gif) | | MacGuyverMarauder Prospect
![Cheap Pair Valve Removal 98 VZ800 Empty](https://2img.net/i/empty.gif) | Subject: Re: Cheap Pair Valve Removal 98 VZ800 Wed Aug 12, 2015 7:56 pm | |
![Cheap Pair Valve Removal 98 VZ800 Empty](https://2img.net/i/empty.gif) | Subject: Re: Cheap Pair Valve Removal 98 VZ800 Wed Aug 12, 2015 8:16 pm | |
| Good trick with the mod and cheap as well, Looks well with open jugs. | |
![Cheap Pair Valve Removal 98 VZ800 Empty](https://2img.net/i/empty.gif) | Subject: Re: Cheap Pair Valve Removal 98 VZ800 Wed Aug 12, 2015 9:23 pm | |
| Good idea crimping the tubes, looks good ![Cheap Pair Valve Removal 98 VZ800 2170595768](/users/2611/31/42/84/smiles/2170595768.gif) | |
| ![Go down](https://2img.net/i/empty.gif) | | Ken1964 Valued Member
![Ken1964](https://2img.net/i/fa/i/avatars/gallery/Divers/Divers_30.gif)
![Cheap Pair Valve Removal 98 VZ800 Empty](https://2img.net/i/empty.gif) | Subject: Re: Cheap Pair Valve Removal 98 VZ800 Fri Aug 14, 2015 9:16 pm | |
| Your a very clever man, excellent job. | |
![Cheap Pair Valve Removal 98 VZ800 Empty](https://2img.net/i/empty.gif) | Subject: Re: Cheap Pair Valve Removal 98 VZ800 Fri Aug 14, 2015 9:59 pm | |
| Good write-up Josh. I followed this guys instructions Moccasin Mike to remove the PAIR valve from my '01 Volusia. Went as far as Step 2, couldn't really see the point of a complete removal - really neatens up the side - simple mod well worth doing. ![Cheap Pair Valve Removal 98 VZ800 <a href=](<a href=) ![Cheap Pair Valve Removal 98 VZ800 DSC08608%20-%20Copy_zpsc5pptjbk](https://2img.net/h/i758.photobucket.com/albums/xx225/katsd11/DSC08608%20-%20Copy_zpsc5pptjbk.jpg) " /> | |
![Cheap Pair Valve Removal 98 VZ800 Empty](https://2img.net/i/empty.gif) | Subject: Re: Cheap Pair Valve Removal 98 VZ800 Sun Aug 23, 2015 8:53 pm | |
| Looking good Josh ![Cheap Pair Valve Removal 98 VZ800 184121345](/users/2611/31/42/84/smiles/184121345.gif) | |
![Cheap Pair Valve Removal 98 VZ800 Empty](https://2img.net/i/empty.gif) | Subject: Re: Cheap Pair Valve Removal 98 VZ800 ![Cheap Pair Valve Removal 98 VZ800 Icon_minitime](https://2img.net/i/fa/icon_minitime.gif) | |
| ![Go down](https://2img.net/i/empty.gif) | | | Cheap Pair Valve Removal 98 VZ800 | |
Latest topics | » Hello
» Howdy
» VZ 800 K7
