 Rear shock spring removal possible ?
2 posters
Scooterboy
Rear shock spring removal possible ?  Empty
PostSubject: Rear shock spring removal possible ?    Rear shock spring removal possible ?  Icon_minitimeMon May 24, 2021 12:21 pm
Hi all ,
Looking for a bit of advice , has anyone stripped the rear shock absorber unit .
I need to remove the spring as it is rusty on underside and want to have it powder coated .
I am thinking that the bottom mount will unscrew from shaft once I remove spring tension allowing spring removal.
Or I could be wrong !
Anyone attempted this before ?
Cheers ..
hmac
hmac
PostSubject: Re: Rear shock spring removal possible ?    Rear shock spring removal possible ?  Icon_minitimeThu May 27, 2021 11:33 am
Find a safe way to compress the spring and you will probably find a locking nut at the end of the plunger shaft undo it and the mount should then unscrew allowing you to remove the spring. That's how I did it on my VZ800, just don't mimic my dodgy ratchet strap and angle iron spring compression rig, it made my bum squeek.
» Rear Shock for M800
» Rear shock length on Marauder 800?
» VL 800 Rear wheel removal
» Vs800 rear wheel removal please help
» ...the piece of cake rear wheel removal
Rear shock spring removal possible ?  Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Rear shock spring removal possible ?  Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Rear shock spring removal possible ?  Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Rear shock spring removal possible ?  Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Rear shock spring removal possible ?  Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Rear shock spring removal possible ?  Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Rear shock spring removal possible ?  Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Rear shock spring removal possible ?  Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Rear shock spring removal possible ?  Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Rear shock spring removal possible ?  Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Rear shock spring removal possible ?  Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Rear shock spring removal possible ?  Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Rear shock spring removal possible ?  Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Rear shock spring removal possible ?  Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Rear shock spring removal possible ?  Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Rear shock spring removal possible ?  Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Rear shock spring removal possible ?  Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Rear shock spring removal possible ?  Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Rear shock spring removal possible ?  Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Rear shock spring removal possible ?  Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
