 vs 1400 final drive in a vs 800
3 posters
Petrolhead750
vs 1400 final drive in a vs 800 Empty
PostSubject: vs 1400 final drive in a vs 800   vs 1400 final drive in a vs 800 Icon_minitimeThu Sep 02, 2021 8:51 pm
hi all, firstly hello this is my first post and secondly my apologies if i am posting in the wrong place as this is my first foray into forum chat.
my situation is i have a custom i have built using a xv750 engine and vs800 wheels front end and drive the rest was made from scratch ( the wife has a vs800 intruder trike). now its on the road i realize the engine and final drive are not really compatible, it basically revs to high.
my questions are dose anyone know the ratios for the final drives of the vs 600 vs 800 and vs 1400? not the info you can get from Suzuki as that will take into account the rotation of at least one cog before you get to the drive shaft, what i am after is purely rotation of the drive shaft to one rotation of the back wheel?
also i see a lot of people are doing the 1400 to 800 diff swap but it is not vs to vs, i have not seen any info to suggest the compatibility of a vs 800 with a vs 1400 diff.
also is the vs 600 and vs 800 diff a strait swap no mods needed, if so dose the vs600 diff have a different ratio to that on the 800?
 to clarify something from above if you ask Suzuki what the final drive ratio is for the vs 800 and vs 1400  they will tell you its 3.09 :1 and 2.66:1 respectively ( i think, i haven't got that info at hand at the moment) but i know from the bench test that the vs800 is a shade over 4:1 when only involving the shaft to wheel ratio.
i believe that the vs 1400 diff would be a better match to my engine but i dont know if it will fit in the frame or the bolt pattern line up( it mounts to the original vs800 swing arm.) i am ok for a bit of machining if necessary but i don't want to buy another diff if i haven't got any chance of making it work.
thanks in advance and i eagerly await your knowledge.
beachartist
beachartist
PostSubject: Re: vs 1400 final drive in a vs 800   vs 1400 final drive in a vs 800 Icon_minitimeTue Sep 14, 2021 6:28 am
I have grafted a final drive(driveshaft and diffhead) from a 1400 into a c 50 (800 cruiser) the only things I had to do were shorten driveshaft approx 30mm(disc grinder and steady hand) and slightly oval the three mounting holes in the c 50 swingarm-driveshaft tunnel. it has transformed the bike from something slightly breathless at 100k into a very relaxed ride. I highly recommend it.
admin
The Final Say!
admin
PostSubject: Re: vs 1400 final drive in a vs 800   vs 1400 final drive in a vs 800 Icon_minitimeTue Sep 21, 2021 7:36 pm
» Suzuki VS 1400 Final Drive Mod
» VS1400 Drive & Shaft Modification ......................How To Thread.
» the ratio of the primary drive (transmission) of the Intruder 1400
» Final drive
» vs 700 final drive - does this fit into VX 800 ?
vs 1400 final drive in a vs 800 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
vs 1400 final drive in a vs 800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
vs 1400 final drive in a vs 800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
vs 1400 final drive in a vs 800 Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
vs 1400 final drive in a vs 800 Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
vs 1400 final drive in a vs 800 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
vs 1400 final drive in a vs 800 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
vs 1400 final drive in a vs 800 Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
vs 1400 final drive in a vs 800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
vs 1400 final drive in a vs 800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
vs 1400 final drive in a vs 800 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
vs 1400 final drive in a vs 800 Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
vs 1400 final drive in a vs 800 Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
vs 1400 final drive in a vs 800 Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
vs 1400 final drive in a vs 800 Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
vs 1400 final drive in a vs 800 Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
vs 1400 final drive in a vs 800 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
vs 1400 final drive in a vs 800 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
vs 1400 final drive in a vs 800 Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
vs 1400 final drive in a vs 800 Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
