 Broken key
2 posters
JimboJ
Broken key Empty
PostSubject: Broken key   Broken key Icon_minitimeMon May 01, 2023 12:18 pm
Hi, had anyone for any ideas how to get a key out of the fuel cap. I took the tank off to replace the seals on the fuel tap. I left the cap open with the key in it. I've gone and kicked the key and snapped it off with nothing showing.
Yep total clutz
Jimbo
Two-Bears
* VZ Guru *
Two-Bears
Broken key Empty
PostSubject: Re: Broken key   Broken key Icon_minitimeSat May 06, 2023 12:03 am
Hello, I have been in this situation twice, my remedy was successful once and failed once but maybe It will be a win for you and well worth a go. Clean the two broken ends of the key as best you can with something like surgical spirit and when dry put some decent quality super glue on the key end and stick it on to the broken piece in the lock,,, give a few seconds for it to dry and then gently try to extract the broken piece. As I say it worked once and I think the failed attempt was because the broken piece had turned slightly in the lock and jammed. If you still have not got the broken bit  out you lose nowt by giving it a try
JimboJ
Broken key Empty
PostSubject: Re: Broken key   Broken key Icon_minitimeSun May 07, 2023 11:29 pm
Thanks, it's stuck in there 😭.
I've spent ages with tweezers trying to turn it a bit but no joy.
Broken key Empty
Broken key
» Broken key
» Hello, help with broken Lamda
» Broken C800 rear indicators
» VZ800 Marauder broken clutch cam.
» Vz800 -97 only runs on one cylinder possible broken wire.
Broken key Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Broken key Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Broken key Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Broken key Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Broken key Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Broken key Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Broken key Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Broken key Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Broken key Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Broken key Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Broken key Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Broken key Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Broken key Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Broken key Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Broken key Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Broken key Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Broken key Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Broken key Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Broken key Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Broken key Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
