 Chrome Tank & Speedo Trim on C800........................By Mistress K
4 posters
Chrome Tank & Speedo Trim on C800........................By Mistress K Empty
PostSubject: Chrome Tank & Speedo Trim on C800........................By Mistress K   Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeTue Jan 03, 2012 6:48 pm
Thread reproduced with the express permission of Mistress K
Time: 5 minutes
Tools needed: 6mm hex key, 10mm box wrench
instructions:
Remove rear bolt from pillion seat and lift off seat.
Remove the 2 bolts in rear tab of rider saddle & lift off saddle
Chrome Tank & Speedo Trim on C800........................By Mistress K 37
Chrome Tank & Speedo Trim on C800........................By Mistress K 38
Next I took off the speedo console..
Time: 2 minutes
Tools needed: 3mm hex key
instructions:
Remove bolts from speedo console (2 at front corners, 1 at bottom of console). lift up, push back rubber housing covering plug for wiring. Depress tab on top of wiring harness plug while pulling on plug & remove
Chrome Tank & Speedo Trim on C800........................By Mistress K 39
To install my chrome tank trim.
Time: 20 minutes
Tools needed: small flat-bladed screwdriver, hair dryer, tinsnips
Instructions:
Use screwdriver to prise apart channel in chrome trim & attach at tank seam under saddle first.
Continue to push trim onto tank seam, heating the trim with the hairdryer to bend more easily around curves and
corners.
finish under other side of saddle, and use tin snips to cut to length
Chrome Tank & Speedo Trim on C800........................By Mistress K 40
Looks much more finished now!
Chrome Tank & Speedo Trim on C800........................By Mistress K 41
I had enough left over to finish the edge of the speedo console as well.
Time: 15 minutes
Tools needed & instructions:
Same as tank trim above
Chrome Tank & Speedo Trim on C800........................By Mistress K 42
I think it looks pretty damn sweet!
PostSubject: Re: Chrome Tank & Speedo Trim on C800........................By Mistress K   Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeTue Jan 03, 2012 10:06 pm
Nice
PostSubject: Re: Chrome Tank & Speedo Trim on C800........................By Mistress K   Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeWed Jan 04, 2012 7:37 pm
Easy and cheap mod that really does finish a bike off Chrome Tank & Speedo Trim on C800........................By Mistress K 2170595768
PostSubject: Re: Chrome Tank & Speedo Trim on C800........................By Mistress K   Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeWed Jan 04, 2012 8:44 pm
I agree, I bought my trim for less than £6 and it took ten min's to do.
PostSubject: Re: Chrome Tank & Speedo Trim on C800........................By Mistress K   Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeSun Aug 04, 2013 12:04 am
Sweet mod!
PostSubject: Re: Chrome Tank & Speedo Trim on C800........................By Mistress K   Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeSun Aug 04, 2013 2:33 pm
Very often its the cheap and easy mods that can make the difference and this is one of those
» Speedo / Tank Trim
» 4" Chrome Riser Install on C800..........................By Mistress K
» Chrome Triple Tree on C800...............................By Mistress K
» New mods, Chrome Speedo Visor / Choke Knob & DIY Chrome Fork End Caps
» Looking for headlight trim & tank badge
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Chrome Tank & Speedo Trim on C800........................By Mistress K Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
