 Chrome Triple Tree on C800...............................By Mistress K
3 posters
Chrome Triple Tree on C800...............................By Mistress K Empty
PostSubject: Chrome Triple Tree on C800...............................By Mistress K   Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeTue Jan 03, 2012 7:07 pm
Thread reproduced with the express permission of Mistress K
Chrome Triple Tree
First I stripped off the stock risers, getting getting my husband Tanker to hang onto the bars for me
Chrome Triple Tree on C800...............................By Mistress K 50
Tanker seems a little confused as to why the forks won't turn for him Wink
Time: 15 minutes
Tools needed: torque wrench, 19mm socket, 6mm hex socket, flat bladed screwdriver & a friend or family member
Instructions:
Cover your tank and front fender with a towel first! crank the bars all the way over in one direction, then get the 19mm socket on your torque wrench from the rear of the front end and crack the riser bolts loose from the bottom of the triple tree clamp, but do not remove the bolts yet as they are torqued to about 50 foot-pounds, so adjust your wrench accordingly.
Use the flat bladed screwdriver to carefully prise off the chrome hex drive bolt covers on the riser caps, and then use the 6mm hex socket to remove the riser caps. have your assitant hold the bars while you switch back to the 19mm socket and completely remove the bottom of the stock risers.
Save the washers from the top and bottom of the triple tree clamp! your helper may find it easier to hold the bars out of the way if you carefully snip the cable ties that bind the wiring to the bars.
Next I installed the triple tree cover, after putting an iron cross decal on it front and centre
Chrome Triple Tree on C800...............................By Mistress K 51
Lookin' pretty sweet!
time: 5 minutes
tools needed: willpower, towel, rubber mallet (persuader)
instructions:
Seat the rear side of the cover first, as you will have to use some force to get it over the ends of the triple tree clamp bolts (the bolts threaded horizontally into the triple tree that stick out just a little directly behind the forks). then push the front on as well. lay the towel over the cover (to avoid any scratches or other marks), then use your mallet to tap it into place. it should sit just about flush with the triple tree itself
PostSubject: Re: Chrome Triple Tree on C800...............................By Mistress K   Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeTue Jan 03, 2012 10:08 pm
There well cool
PostSubject: Re: Chrome Triple Tree on C800...............................By Mistress K   Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeWed Jan 04, 2012 7:36 pm
Mistress Ks bike is the only intruder that I have seen the Chrome triple trees on which I am shocked about as they look so bloody good Chrome Triple Tree on C800...............................By Mistress K 123721 I have not seen them advertised either Suspect
» Chrome Triple Tree Cover
» Leather Mud Flap Mod on C800.............................By Mistress K
» Chrome Tank & Speedo Trim on C800........................By Mistress K
» raked triple tree.
» * Mistress K's adventure in modifying a Suzuki Intruder C50 / C800 *
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Chrome Triple Tree on C800...............................By Mistress K Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
