 VL Bars Fitted To A Suzuki M50 / M800
Spike
8 posters
VL Bars Fitted To A Suzuki M50 / M800 Empty
PostSubject: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeTue Jul 24, 2012 10:31 pm
VL Bars Fitted To A Suzuki M50 / M800 2012-07-24163820
Fitted VL800 bars today,here is the finished job.Took pics but not to good.The difference is excellant,my arms are now bent when riding,and much more comfortable.The cables had to rerouted to the front of the trees
VL Bars Fitted To A Suzuki M50 / M800 2012-07-24163425
from apparently in 2007 the cables were shortened on the M800,also had to cut 2" of each end of the bars
VL Bars Fitted To A Suzuki M50 / M800 2012-07-24111009
This has to be done with a pipe cutter which is capable of cutting 28mm pipe,ie:more than 1",the reason for this was because the throttle cables and brake and clutch cable would not reach,as you can see by the first pic,you still get a lot more pull back.I have had a quick ride out and everything works fine,now I have got the riding position of the c800,and the looks of the M800,best of both bikes.A good tip I was told on line was to take the headlight out of the way (two bolts) easier to feed the levers through the trees.Also I would stress remove your tank,saves you worrying if you are doing the job on your own,a second pair of hands would of been great,but like always you say to yourself "oh it's easy wont take long" six hours later and you getting dressed ready for a test run.Good thing is it's done now,and I am a happy bunny.
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeTue Jul 24, 2012 10:55 pm
Looks great Alfie VL Bars Fitted To A Suzuki M50 / M800 2170595768 Those bars look like they make a world of difference in the comfort department VL Bars Fitted To A Suzuki M50 / M800 2645662097
Spike
Spike
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeWed Jul 25, 2012 12:11 am
Very nice. Really want to do similar to mine. I really would like more pullback. VL Bars Fitted To A Suzuki M50 / M800 2645662097
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeWed Jul 25, 2012 2:49 am
Crickey mate that riding position is sooooooo different to the standard M. Looks like you will be very comfortable now with much more relaxed arms, compared to before.
Excellent job VL Bars Fitted To A Suzuki M50 / M800 3322349030
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeWed Jul 25, 2012 2:38 pm
Looking great alfie, will be interesting to know how much difference they have made to your comfortVL Bars Fitted To A Suzuki M50 / M800 2645662097
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeWed Jul 25, 2012 7:10 pm
Looks more comfortable but personally I couldn't put up with not seeing all the speedo .... just my opinion but I'm a bit OCD with stuff like that
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeWed Jul 25, 2012 10:48 pm
Hi thanks for your comments,the comfort is great,always a pleasure to ride bikes,but if you can can make them fit you for your purpose then even better.Mick I only ride with one set a bars on at a time,mainly a weight issue with petrol being expensive,but I take your point.Spike it is a no brainer m8, if you can get hold of a pair of bars from the c800/vl800 go for it.I was out today round the horseshoe pass North Wales and it handled great,just got to sort the seat out now.VL Bars Fitted To A Suzuki M50 / M800 3498837457
Spike
Spike
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeSat Jul 28, 2012 11:57 pm
It is a must do for me now. I love my M800 but have never liked the handlebars too much. Best place to get hold of c800/vl800 bars anybody?
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeSun Jul 29, 2012 1:35 pm
None on ebay at the moment as I just looked for you but I think you can buy cruiser bars for as cheap as about £50 or so if you look around
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeMon Jul 30, 2012 11:15 am
Hi Spike just keep your eye on ebay,as CC says if you type 1"" handlebars there may be ones that take your fancy.Fitting wise they are simple,now I have how done the job myself,if you get stuck give us a shout.
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeMon May 26, 2014 7:04 pm
I definitely need to get some VL800 bars.
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeMon May 26, 2014 7:22 pm
Spike there is a set on sale by a forum member on e-bay now matey!
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeTue Jun 03, 2014 7:42 pm
Thx for the advice to get some VL800 handle bars  VL Bars Fitted To A Suzuki M50 / M800 2645662097
I mounted the bars using your tip with the headlight, but only needed to loosen one side, and remove the screw from the other side.
I used a hacksaw to cut 5cm from each end, and remembered to drill 2 new holes for the switches and throttle.
It took about 2 hours, and I covered the tank with blankets.
No test today because it's raining  VL Bars Fitted To A Suzuki M50 / M800 536894
VL Bars Fitted To A Suzuki M50 / M800 IMAGE_25
VL Bars Fitted To A Suzuki M50 / M800 IMAGE_26
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeTue Jun 03, 2014 9:40 pm
You will love it m8.Much more relaxed riding position.You can always tweak them by lifting them forward and making mini apes out of them.When you find the best place for them mark the risers and bars,then if you change you can always go back to were you felt most comfortable.I notice you have the clutch cable at the back of the tree,you can leave it at the front if you reroute it under your tank and bring it forward a bit around were you have taken the pair valve off.
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeWed Jun 04, 2014 2:39 pm
I really like it, looks good  VL Bars Fitted To A Suzuki M50 / M800 184121345
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeWed Jun 04, 2014 4:53 pm
Took a short ride today and it really is an entirely different bike, much more cruiser like vs sporty with the other bars.
I need to get used to them, but I think they will be great on long trips.
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeWed Jun 04, 2014 5:04 pm
Hi Kim after a couple of rides you will throwing the bike round corners again,the good thing as you say is they are great for long trips.
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeWed Jun 04, 2014 5:52 pm
Good to know your happy  VL Bars Fitted To A Suzuki M50 / M800 184121345
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeThu Jun 05, 2014 4:15 pm
VL Bars Fitted To A Suzuki M50 / M800 <a href=VL Bars Fitted To A Suzuki M50 / M800 20140605_143532" />
Here is were I have my clutch cable.
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeThu Jun 05, 2014 8:33 pm
I think I'll leave the clutch cable behind the risers for now, and maybe get a longer cable in the future.
It would look a bit off, with a cable crossing over the two cylinders.
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeTue Jun 10, 2014 3:31 pm
First hour long ride with the new bars today.
Now I noticed that because my arms are more bend, they don´t support my body as well when going over 90-100km/h.
So I think I need a screen now  Laughing
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeTue Jun 10, 2014 4:33 pm
I take it your still happy with the riding position?
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeTue Jun 10, 2014 4:49 pm
yep  VL Bars Fitted To A Suzuki M50 / M800 3498837457
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeTue Jun 10, 2014 4:56 pm
Just an excuse to buy a screen then  VL Bars Fitted To A Suzuki M50 / M800 852880 I like it!  VL Bars Fitted To A Suzuki M50 / M800 3498837457
PostSubject: Re: VL Bars Fitted To A Suzuki M50 / M800   VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeTue Jun 10, 2014 5:12 pm
A man after your own heart then Sim.  VL Bars Fitted To A Suzuki M50 / M800 852880
» Thinking of changing my bars on Suzuki M800
» Drag Bars Fitted To Suzuki C800 / C50
» Fitted Custom bars to .......... 1997 Suzuki vz800v
» Ape Hanger bars fitted ............................. 2001 Suzuki Vl800
» Rear crash bars fitted ............................ 2004 Suzuki VL800
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
VL Bars Fitted To A Suzuki M50 / M800 Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
