 Thinking of changing my bars on Suzuki M800
4 posters
Guest
Guest
Thinking of changing my bars on Suzuki M800 Empty
PostSubject: Thinking of changing my bars on Suzuki M800   Thinking of changing my bars on Suzuki M800 Icon_minitimeSat Dec 03, 2011 1:13 pm
Thinking of changing my bars on Suzuki M800 1090754380 I'm thinking about changing my bars but the local cruiser shop said "i cant because of the way my clocks are attached to my standard bars",has anyone changed the bars on a "61 plate M800" .Thinking of changing my bars on Suzuki M800 1337224149
PostSubject: Re: Thinking of changing my bars on Suzuki M800   Thinking of changing my bars on Suzuki M800 Icon_minitimeSat Dec 03, 2011 4:18 pm
Sounds a bit strange to me, the clocks are surely simple attached to the bar by either clamping on, dimple or hole attach which would be very easy to get around.
Hopefully one of the guys with different bars will chip in but I know for a fact it has been done many times
Guest
Guest
PostSubject: Re: Thinking of changing my bars on Suzuki M800   Thinking of changing my bars on Suzuki M800 Icon_minitimeSat Dec 03, 2011 6:18 pm
I agree Dave thought much the same but the cruiser shop in southport told me he has customized a M800 and said he had to keep the original bars because the bars had a complicated clock bracket that he couldn't copy!!!!,,,i expect the clocks just have a clamp of sorts that i can just remove and clamp to my new bars,,,at least I'm hoping Thinking of changing my bars on Suzuki M800 938687981 .
PostSubject: Re: Thinking of changing my bars on Suzuki M800   Thinking of changing my bars on Suzuki M800 Icon_minitimeSat Dec 03, 2011 6:28 pm
Time to get the Allen key out and take a little peek I reckon, 5 minutes and you would have your answer.
If we trusted so called shop mechanics we would never get anything done, so many of them can do no more than follow instructions or unbolt one simple thing to add another simple thing. I would dare to say that 99% of all modifications would have at least originated in one way or another from a guy trying something out in his garage just to see if it would work or not!
PostSubject: Re: Thinking of changing my bars on Suzuki M800   Thinking of changing my bars on Suzuki M800 Icon_minitimeSat Dec 03, 2011 6:37 pm
I've seen a fair few M800's with drag bars on the net, as Mr I says take a little peek and at least you will have an idea of what your up against
Guest
Guest
PostSubject: Re: Thinking of changing my bars on Suzuki M800   Thinking of changing my bars on Suzuki M800 Icon_minitimeSat Dec 03, 2011 6:57 pm
Thinking of changing my bars on Suzuki M800 696333
I took the bar clamps off today and had a look, it looks like they should come off,i think if i take the levers an grips off i should be able to slide the clocks off (or the bars out of the clocks), after loosening there clamps that is,The clock cables are very tight thr is not a lot of play ,,,I don't have the new bars yet so don't want to take to much off as i want to be able to ride it if the sun comes out (not much chance i know).but would feel more confident if someone has removed them,an may have a few tips Thinking of changing my bars on Suzuki M800 184121345
exile
exile
PostSubject: Re: Thinking of changing my bars on Suzuki M800   Thinking of changing my bars on Suzuki M800 Icon_minitimeMon Dec 05, 2011 3:13 pm
On my M800 (2005... so don't know if it's different!) I changed the bars no probs .. the speedo attaches to the bars between the clamps.... you can't change the risers though , because if I remember right the speedo head also mounts to moulded brackets on the riser itself !!
Freemo
Freemo
PostSubject: Re: Thinking of changing my bars on Suzuki M800   Thinking of changing my bars on Suzuki M800 Icon_minitimeTue Dec 06, 2011 11:58 pm
I've got a 2007 m800 and have put drag bars on with no issues. I'm in liverpool too if you want to check them out?
Guest
Guest
PostSubject: Re: Thinking of changing my bars on Suzuki M800   Thinking of changing my bars on Suzuki M800 Icon_minitimeWed Dec 07, 2011 12:28 am
Freemo wrote:
I've got a 2007 m800 and have put drag bars on with no issues. I'm in Liverpool too if you want to check them out?
cheers Freemo, Ive ordered my bars so i might take you up on your offer, I'm in Huyton.
Guest
Guest
PostSubject: Re: Thinking of changing my bars on Suzuki M800   Thinking of changing my bars on Suzuki M800 Icon_minitimeMon Jan 30, 2012 7:43 pm
All done now...dont know what the shop was on about...changed them no probs ...Thanks lads
LINK
» Changing the bars from M800 ones to cruiser bars
» VL Bars Fitted To A Suzuki M50 / M800
» Suzuki VL800 bars on M50
» Drag Bars Fitted To Suzuki C800 / C50
» Fitted Custom bars to .......... 1997 Suzuki vz800v
Thinking of changing my bars on Suzuki M800 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Thinking of changing my bars on Suzuki M800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Thinking of changing my bars on Suzuki M800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Thinking of changing my bars on Suzuki M800 Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Thinking of changing my bars on Suzuki M800 Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Thinking of changing my bars on Suzuki M800 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Thinking of changing my bars on Suzuki M800 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Thinking of changing my bars on Suzuki M800 Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Thinking of changing my bars on Suzuki M800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Thinking of changing my bars on Suzuki M800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Thinking of changing my bars on Suzuki M800 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Thinking of changing my bars on Suzuki M800 Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Thinking of changing my bars on Suzuki M800 Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Thinking of changing my bars on Suzuki M800 Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Thinking of changing my bars on Suzuki M800 Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Thinking of changing my bars on Suzuki M800 Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Thinking of changing my bars on Suzuki M800 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Thinking of changing my bars on Suzuki M800 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Thinking of changing my bars on Suzuki M800 Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Thinking of changing my bars on Suzuki M800 Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
