| Help please with replacement VZ800 Ignition Switch | |
jdk Member
| Subject: Help please with replacement VZ800 Ignition Switch Mon Jan 21, 2013 6:44 pm | |
| Hi my ignition switch has packed up and i have another switch but its not for my vz800 marauder dont know what it is for it has 4 wires black green red and a black with white tracer also it has no park position just on off so can any one tell me what i need to do to wire it into my vz thanks jason | |
| Subject: Re: Help please with replacement VZ800 Ignition Switch Mon Jan 21, 2013 7:13 pm | |
| Jason its in possible to give advice on an ignition switch if we don't know where it has come from, if we new where it came from we could search a pdf wiring diagramme and work it out. Although even with that said, I have just had a look at the vz800 wiring diagrame and that also only has 4 wires going to the ignition so it is a good bet that it will work but as already said without knowing where it came from no body can give a definative answer as to what order the wires from your VZ should go on the switch that you aquired. Sorry mate, wish I could have been a little more posative. Trial and error may be your only way if you are determined to use that switch but that could be dodgy. | |
| | | jdk Member
| Subject: Re: Help please with replacement VZ800 Ignition Switch Mon Jan 21, 2013 7:48 pm | |
| Hi thanks for the quick reply i have been told the new switch is of a ktm and my vz has 5 wires orange red grey orange/red and brown | |
| Subject: Re: Help please with replacement VZ800 Ignition Switch Mon Jan 21, 2013 11:00 pm | |
| Ah then I apologise for giving the wrong info but I have just looked at the wiring diagramme again and still only count 4 wires, so I am confused :what1: | |
| Subject: Re: Help please with replacement VZ800 Ignition Switch Tue Jan 22, 2013 5:59 am | |
| Just been reading this and I am not sure what we are missing as the pdf in the Clymer manual shows 4 wires. How very confusing? | |
| | | jdk Member
| Subject: Re: Help please with replacement VZ800 Ignition Switch Tue Jan 22, 2013 9:26 am | |
| Hi don't know if this helps my bike is a vz800 v 1997 and this is a wiring diagram i hope
http://s1179.beta.photobucket.com/user/Jason_Kingsley/media/img003_zpse297f32f.jpg.html | |
| Subject: Re: Help please with replacement VZ800 Ignition Switch Tue Jan 22, 2013 5:07 pm | |
| I do not have access to a 1997 vz800 manual but I have checked the newer vz800 manual - vs800 and the old and new vl800 manuals and they all run on 4 wires so they must have run the one model with a different wiring setup. I will bow out of this one as it is beyond me, sorry | |
| Subject: Re: Help please with replacement VZ800 Ignition Switch | |
