Finally compressed, uploaded and setup. Job done. Need sleep. :sleep: :sleep:
elsonico Member
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Apr 06, 2013 8:16 am
Thank you Marcin, you're a star!
MarcinG Valued VIP Member
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Apr 06, 2013 9:51 am
You're welcome. Bear in mind though, when removing the long screws, just loosen them up and pull, to remove the whole assembly from inside of the bar otherwise you'll have a washer and nut stuck inside. I learned it the hard way. *rattle rattle*
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Apr 06, 2013 10:37 am
Good video Marcin when you undo the bar end weights only undo them a little then tap the screw inwards to release the inner part, then with the screw undone (not out) pull the bar end weight and the inner part complete with nut and washer comes out
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Apr 06, 2013 2:07 pm
I would be very careful using super glue (I think that's what your using) when fitting something like that, better to use a glue that doesn't set quite so quickly. Looks good though.
Sanddancer Valued Member
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Apr 06, 2013 7:03 pm
Thanks for taking the time to do that Marcin. Going to be my next mod I think
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Apr 06, 2013 8:05 pm
I used Loctite Gel...super something. It has a gel consistency and was setting slow enough to allow me to pull the grip off and put it back on. I think I was borderline successful with it...that's why I had problems rolling it on. Something slower reacting would help indeed.
elsonico Member
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Apr 06, 2013 8:49 pm
alright, fitted my new grips today. Getting the throttle cables out of the old grip and into the new one was a PAIN in the ***...took me about 20 minutes and some serious swearing. However, the grips look great. Thanks again for your help, keep up the good work!
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Apr 06, 2013 9:05 pm
Good man! I'm glad I could help
Now...Pics or it didn't happen!
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Apr 06, 2013 10:08 pm
nice vid marcin
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Apr 06, 2013 10:37 pm
Question is...who waited long enough for "sad panda" moment
pledge Valued Member
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Apr 06, 2013 11:53 pm
Another good video. Was the sad panda moment when it didn't start right away?
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sun Apr 07, 2013 12:03 am
yep I saw it lol you've got to watch them all the way through just in'case there's any surprises loved the bleep moment too
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sun Apr 07, 2013 12:20 am
I'm starting to feel more comfortable with my video editing software now...bleep took me 15 minutes to find and add haha. I'll try to do bloppers on each video from now on since I'm discarding tons of footage.
elsonico Member
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sun Apr 07, 2013 11:05 am
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sun Apr 07, 2013 2:34 pm
Looking Good.
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sun Apr 07, 2013 7:14 pm
Its the little things that really make the difference and they are very cool
coffeescoffer Member
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Fri May 31, 2013 3:50 am
Just wondering Marcin, if the outer part of the throttle side grip will come off so that it could be put on over a stock throttle twister bit? I would not think that the heat pads of a grip warmer would enable smooth throttle action if put on the bar directly, so putting them under just the outer bit makes sense.
Jimmyboy Valued Member
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Oct 26, 2013 3:06 pm
Marcin just watched your vid so of into the garage, 15mins later I had these fitted !!! Highway Hawk grips chrome metal not plastic for £20 notes from a local trader I know.
Thanks for your vid mate and the inspiration !!!
Jim.
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Oct 26, 2013 3:23 pm
That's a good buy, Easier to fit than it may at first seem even for the first time
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Oct 26, 2013 3:25 pm
Yep your right crash, just needed to take the slack up in the cables afterwards....job done !!!
Jim.
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Oct 26, 2013 3:28 pm
Adding bits like that really make you feel like the bike is yours and its even better cause you know you did it
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Oct 26, 2013 3:30 pm
Totally agree mate, you have to make these things your own.
Jim.
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Oct 26, 2013 3:39 pm
They look Nice job Jim
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Oct 26, 2013 4:43 pm
Can't tell you how happy it makes me to see that the vid helped someone. Cheers Lovely grips.
DaveC Member
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Oct 26, 2013 6:44 pm
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Oct 26, 2013 7:14 pm
Very nice Jim, looks cool.
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Oct 26, 2013 9:02 pm
Nice job.
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Sat Oct 26, 2013 10:21 pm
Look sound them Jim.
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Wed Jan 01, 2014 4:14 pm
Marcin where did you buy your grips from may I ask? Also is the 2010 VL800 (C800LO) throttle assembly different to yours? Any help or advice would be gratefully recieved,
Peter
Bigredbus4468 Member
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Wed Jan 01, 2014 4:50 pm
Nice one.
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Wed Jan 01, 2014 6:06 pm
As for the 2010 differences, I'm afraid I don't know but I doubt that the changes would affect the way a grip fits in.
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Wed Jan 01, 2014 6:13 pm
Marvin have you ridden these grips? Any vibes? Are they metal? Cheers Kevin
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Wed Jan 01, 2014 6:48 pm
The throttle assembly is visually different but the grips are the same and fit fine like Marvin says, I've got them on my 09 model which is the same as the 2010 model.
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Wed Jan 01, 2014 7:17 pm
Marvin :)
Yes, I got them on my bike all the time. Bought them in January so it's been a year now and they still look like new. They're not metal, they're billet aluminium. Lightweight and very nicely done.
Grip is unbelievable...rubber is very good quality. It actually survived ripping them off the bar once already (left grip)
Vibes? as in vibrations? I had a problem with it but I think it was a problem with my handlebar in general. I wouldn't attribute extra vibrations to the grips. I did however replace the sharp tips that they come with, with end bar weights from stock. So mine look like that now:
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Wed Jan 01, 2014 8:04 pm
Thanks 'Marvin' & Sim. as for the bar ends I'd like to use the plain Kuryakyn type with a contoured(large) throttle assister but then I'd probably have vibration problems, do you get much in the way of vibe's now Sim?
:cmate:
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Wed Jan 01, 2014 8:15 pm
I think I was the only sissy complaining about vibrations on handlebar
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Wed Jan 01, 2014 8:21 pm
I've never had any vibration problems at all Peter, I even use thin gloves in summer without problem, Marcin has though, so possibly it's just the difference in our hands?
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Wed Jan 01, 2014 9:01 pm
Ye, I actually filled the handlebar with fine sand to dampen the vibrations. It was only later that I found out I had finger joint inflammation that was making everything feel worse than it was.
However...without the bar end weights I had problems seeing anything in mirrors, it was so bad. After sand, perfect at 60mph :}
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Thu Jan 02, 2014 5:59 pm
Ah I'll see what I can sort out then & thanks for the recomendations Marcin & Sim. I used to know a friend who used lead substitute for his fishing so will seek him out again to renew friendships & see if he knows where to get some of the substitute as I dont like the idea of sand in the bars as it may travel to the twistgrip assembly possibly? I do wonder though if the Kuryakyn throttle assist will fit the chinese replacements Marcin as you do not show the end assembly on the throttle side on any pictures or on the video so I wonder if you can tell me if it looks like the same fitting at all please?
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Thu Jan 02, 2014 6:15 pm
What's a Kuryakyn throttle assist Peter? I've just googled it and all I can find is the throttle boss that these cheap grips come supplied with.
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Thu Jan 02, 2014 6:19 pm
I must admit I don't get it either... these grips come with throttle boss so why replace with expensive Kuryakyn stuff?
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Thu Jan 02, 2014 6:34 pm
The throttle assist/boss is a larger paddle shaped piece that sits under the heel of your hand as against the small boss that comes with the chinese version that just protrudes into the twistgrip area & seems as much use as a chocolate fireguard to me as i use an M & P clip on version at the moment on the original twistgrip.
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Thu Jan 02, 2014 6:38 pm
Whatever floats your boat mate but I found it perfect and unless your grip tries to unwind itself with a force of a truck, you'll have no problems at all keeping throttle locked with it.
I'd say "try before you buy".
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Thu Jan 02, 2014 6:55 pm
I have weakened grip in my hands Marcin due to carpal tunnel operations so find the bigger one to assist me on long trips. On my Pan European 1300 it was a brilliant help as it had been on the R11100RT I had also & it has helped on the Intruder so I will try it first obviously & 'suck it & see' as they say.
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Thu Jan 02, 2014 7:05 pm
That makes sense mate. Go for bigger one.
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Thu Jan 02, 2014 7:20 pm
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Thu Jan 02, 2014 9:47 pm
Marcin I've just re-viewed your pic with the bar end weights re-installed & want to ask did you try to use the throttle boss as well with the end weights before going to them without the boss installed or not? I summise the screws on the boss end protruded too far to use the boss & the weights & did you cut the threaded sections out of the grips to fit the weights again?
Subject: Re: 1" custom grips - installation - video ...... Suzuki Intruder Thu Jan 02, 2014 9:58 pm
I think I tried but I couldn't be asked to mess about with screws and holding it in place. Also, the way I have everything setup on my handlebar - the weights do not turn along with throttle as I used the stock mounting too (long screw and 2 rubber bushings that bulge out and hold the lot in place). This way I got about 1mm space between the grip and weight, allowing it to vibrate freely.
