 Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder
pledge
twenty2
Sanddancer
12 posters
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Empty
PostSubject: Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder    Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeWed Apr 10, 2013 8:06 pm
Tried my first hand at doing some leatherwork for a useful little accessory…. A kind of mini ‘dashboard’ to mount on the bottom inside of my screen to carry lightweight bits… phone/specs/passport etc, making them easily accessible.
Components:
Ebay black leather jacket – cost £6
Contact adhesive - £3
2 part cone rivets - £2 for 50 On Fleabay
Tobacco tin – from stock
Black thread – from stock
Old glasses case – from stock
Offcut signage plastic (foamex) from work.
Step 1
Cut the foamex to the size of the metal framework of the screen, highlighted green.
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Green
Step 2
Make a document pocket from leather by cutting an oval which when folded back on itself will be your chosen pocket shape.
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Oval
Use contact adhesive to make this double thickness panel. I used a piece with a seam down the middle, for a little decorative feature. I then used a scalpel and straight edge to trim a neat edge.
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Pocket
Step 3
Cut a piece of leather which will be the piece facing you as you sit on the bike, leaving an inch or so border beyond the foamex. Mark position of pocket, so you can add contact adhesive where the pocket edge will sit. Also apply glue to the ‘border’ of the pocket, and press together once touch dry.
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Pocket-assembly
Step 4.
Mark rivet holes around pocket border, and punch with bradawl. Here are the 2 part rivets:
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Rivets
Step 5. Push back of rivet up through leather, then place coned top on, and tap together. (I drilled a conical hole in scrap wood, to sit the rivet head in when tapping to avoid distorting it.
The rivets are pretty strong, so add to the construction, but add decorative detailing too.
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Pocket-loose
Step 6.
Your inner face is now complete. Glue it to the foamex.
Step 7.
Glue matching leather to other side of foamex, making sure your ‘overhanging’ leather surfaces are glued together. Use a knife handle or something to press the leather right up to the edge of the foamex, so it defines the shape.
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Deck
Step 8. Trim the edge neat, using a scaplel. As an optional extra, mark evenly spaced dots all round the edge, punch with a bradawl, then run stitching round for edge setailing (this handywork was courtesy of Mrs Bigmal... not known for her sewing prowess, but wahta  job!)
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Stitching
Step 9.
Drill through leather panel in line with screen bolts, and sandwich in place. Here's the end result:
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Onbike
Step 10.
I also pimped a tobacco tin...
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Tobaco
and an old glasses case, so I can carry my phone and specs. These aaccessories will be mounted with Velcro, so they can be changed if needed in future.
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Access
Sorry that's a bit long winded, but hope you like the end result Wink
PostSubject: Re: Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder    Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeWed Apr 10, 2013 8:20 pm
Good mod and write up Mal,thanks for sharing.
PostSubject: Re: Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder    Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeWed Apr 10, 2013 8:41 pm
Excellent Job Mal! It looks great! Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  2170595768 Very detailed and informative write up too Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  433968
Sanddancer
Sanddancer
PostSubject: Re: Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder    Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeWed Apr 10, 2013 9:04 pm
Looks good Mal, and practical too.
Wish I'd known, I could have got you to make my tank bib!
Laughing
PostSubject: Re: Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder    Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeWed Apr 10, 2013 9:20 pm
Cheers mate....no, believe me, your £100 or whatever was well spent! I'm pleased with what I've made, but it's nowhere near as gorgeous as that tank bib!
twenty2
twenty2
PostSubject: Re: Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder    Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeWed Apr 10, 2013 9:22 pm
Nice mod.
The result ooks really professional
PostSubject: Re: Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder    Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeThu Apr 11, 2013 12:02 am
Excellent mod and write up Mal, good on you Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  3322349030
PostSubject: Re: Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder    Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeThu Apr 11, 2013 12:15 am
Thanks all Wink
PostSubject: Re: Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder    Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeThu Apr 11, 2013 7:28 am
Really good that Mal, doesn't look like a home made item at all mate.
pledge
pledge
PostSubject: Re: Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder    Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeThu Apr 11, 2013 8:35 am
Looks really good.
PostSubject: Re: Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder    Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeThu Apr 11, 2013 11:25 am
Good job Mal
PostSubject: Re: Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder    Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeFri Apr 12, 2013 4:03 pm
yeh thats well good
JJW
JJW
PostSubject: Re: Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder    Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeSun Apr 14, 2013 2:14 pm
Nice!!
Thanks' for the write-up and great pictures.
You two are a team.
PostSubject: Re: Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder    Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeSun Jun 09, 2013 2:02 pm
After seeing this mod in the flesh so to speak on the recent Normandy Tribute Tour I just want to say how impressed I was with it & will attempt making a similar product myself when I have a bit of time. Great job Mal. Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  3498837457
PostSubject: Re: Leather Screen Pouch Fitted .......... 2005 Suzuki M800 Intruder    Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeSun Jun 09, 2013 5:35 pm
Thanks mate.... it was dead handy, especially for things like passport control.
But.... major blooper with just velcroing the phone holder to the leather - wouldnt do it that way again. Wish I'd done it like the main central pocket.... belt & braces, contact adhesive & rivets.
For anyone interested, I held up our merry little band in France for about 30 mins while we all searched for my mobile. As I was slowing, coming into a motorway rest area, doing about 50mph, I saw the leather phone holder, complete with mobile, detach itself from the leather panel and drop like a stone.
I pulled up as quick as I dare, and wandered aimlessly up & down the hard shoulder looking for it. Eventually one of the group, Ian, said "Are you sure it's not caught on your bike somewhere?" and miraculously it had got lodged in between the crankcase and my footpeg!!
Wasnt even a decent phone, but it was still a big releif to get it back.
If anyone's thinking of making one of these, I recommend a further mod which I've still to do, and that's removing the panel and refitting it with rubber washers to let it 'breathe' - I'm getting condensation between the leather and the inside face of the screen.
» Marko's .......... 2005 Suzuki M800
» New Members .......... 2005 Suzuki M800
» Complete Bargain! .......... 2005 Suzuki M800
» How to make your own Screen Lowers for Suzuki Intruder
» Custom screen fitted spot light brackets .......... 2001 Suzuki VL800
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby Jack70 Today at 4:35 pm
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Leather Screen Pouch Fitted .......... 2005 Suzuki M800  Intruder  Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
