 Hiding cables
5 posters
Hiding cables Empty
PostSubject: Hiding cables   Hiding cables Icon_minitimeThu Apr 18, 2013 10:11 am
Hi gents,
As you well know, the cable management on 2003 Volusia sucks big time.
I'm thinking about how could I hide them and, following some sightings from Matlock, I wonder if it would be possible to feed them through the handlebar.
To all you savvy gents, how much can you bend throttle/clutch cables?
I assume the more bent they will be, the more wear will occur on bends..but that would be something to bear in mind when servicing and as long as they will work without a problem, it's something I could live with.
Failing that, maybe at least I could hide the electric stuff.
I can't believe I'm saying all that.... here I was shaking when putting custom grips on and now I'm thinking about drilling holes in handlebar.
Damn you modding bug... it's ALL YOUR FAULT! Hiding cables 215375Hiding cables 2343124779
Hiding cables Empty
PostSubject: Re: Hiding cables   Hiding cables Icon_minitimeThu Apr 18, 2013 6:47 pm
Electrics would be a massive headache because you would have to either splice all the wires or separate them at the switch end. I remember dave (Mr I) considered this when he put ape hangers on his bike but found it to be to awkward. He said it would have been easy enough for one side but the other side had double the wires so he just extended them. Have a look at his ape hanger thread, it is mentioned in there LINKY
As for the cables, if you don't like the way the cables stick out on your model, might be easier to go for throttle assembly off of a later model. They do come up occasionally on ebay, then you would have the more modern closer fitting cable setup
twenty2
twenty2
Hiding cables Empty
PostSubject: Re: Hiding cables   Hiding cables Icon_minitimeThu Apr 18, 2013 9:52 pm
Bars without cables or wires are so sweet.
Been thinking about doing a mod like that but havent really gotten it going yet. Dont even know if it is possible to fit both cables and throttle inside a 1" bar if you do it yourself.
Found this picture of the mechanics regarding interial throttle. Might be to some help for you in your quest.
Hiding cables Empty
PostSubject: Re: Hiding cables   Hiding cables Icon_minitimeThu Apr 18, 2013 9:59 pm
I think the wiring could be done with standard bars and a bit of work, I don't think the throttle and clutch could though?, once you start bending cables they tend to stick.
Hiding cables Empty
PostSubject: Re: Hiding cables   Hiding cables Icon_minitimeFri Apr 19, 2013 8:25 am
I thought so... so the option for the cables would be to cover them in some chrome brainded sleeving and focus on hiding the wiring.
Sounds like a plan.
And regarding the splitting of the wiring/rewiring etc etc I just had an idea..
Why not roll back the wiring from the case, hide it, make a connector at the end of it and then just run brand new wiring via desired route to the case and connect it to the old ones...making it sort of a modular build, allowing you to relatively easy roll back to the old way.
I'm not sure if I described well what I mean...
Hiding cables Empty
PostSubject: Re: Hiding cables   Hiding cables Icon_minitimeFri Apr 19, 2013 9:24 am
sounded allright to me marcin i got what yopur saying (i think lol)
there is another member that coverd his cables and HT leads if i remember right looked good cant remember what coulor he did them
Hiding cables Empty
PostSubject: Re: Hiding cables   Hiding cables Icon_minitimeFri Apr 19, 2013 4:53 pm
Just be careful that you don't damage the integrity of the bars with overly large holes to get the wires through
Hiding cables Empty
PostSubject: Re: Hiding cables   Hiding cables Icon_minitimeFri Apr 19, 2013 6:51 pm
That's sound advice mate... with 1" it wouldn't take much to knacker the integrity.
Hiding cables Empty
PostSubject: Re: Hiding cables   Hiding cables Icon_minitimeFri Apr 19, 2013 10:30 pm
have you thought about just getting sum different bars ?
Hiding cables Empty
Hiding cables
» carburettor cables??
» Extended throttle cables
» Move the throttle cables?
» Longer cables for vz800
» handle bars and cables
Hiding cables Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Hiding cables Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Hiding cables Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Hiding cables Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Hiding cables Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Hiding cables Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Hiding cables Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Hiding cables Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Hiding cables Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Hiding cables Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Hiding cables Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Hiding cables Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Hiding cables Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Hiding cables Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Hiding cables Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Hiding cables Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Hiding cables Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Hiding cables Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Hiding cables Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Hiding cables Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
