| Polished engine fins after pair valve removal - 2000 Suzuki VZ800V | |
+6JJW petetesch Bunso Steel Mr Intruder shadycowboy AmericanJambo 10 posters | Author | Message |
AmericanJambo Member
| Subject: Polished engine fins after pair valve removal - 2000 Suzuki VZ800V Mon May 13, 2013 11:10 pm | |
| | | shadycowboy Member
| Subject: Re: Polished engine fins after pair valve removal - 2000 Suzuki VZ800V Tue May 14, 2013 1:36 am | |
| I really need to do this. What type of paper did you use?
| Subject: Re: Polished engine fins after pair valve removal - 2000 Suzuki VZ800V Tue May 14, 2013 2:45 am | |
| - shadycowboy wrote:
- I really need to do this. What type of paper did you use?
I first used a dremel with one of the sanding attachments. 5k RPM. Just to knock off most of the paint. Then I switched to 220 grit, then 330 grit sandpaper to give it a brushed look. You can skip the dremel and just start with 100 or 220 grip sandpaper. it just gets clogged quickly which is why I switched to the dremel. Only took me a total of about 30 min. If you want a shiny high polish then you'll have to continue with 800, then 1500, then 2000. Finish that with a metal polish. | |
| Subject: Re: Polished engine fins after pair valve removal - 2000 Suzuki VZ800V Tue May 14, 2013 6:25 am | |
| Looks loads better, good job. | |
| Subject: Re: Polished engine fins after pair valve removal - 2000 Suzuki VZ800V Tue May 14, 2013 10:11 am | |
| Looks cool, makes that engine stand out | |
| | | petetesch Member
| Subject: Re: Polished engine fins after pair valve removal - 2000 Suzuki VZ800V Tue May 14, 2013 5:36 pm | |
| I like it | |
| | | JJW Member
| Subject: Re: Polished engine fins after pair valve removal - 2000 Suzuki VZ800V Tue May 14, 2013 7:21 pm | |
| Subject: Re: Polished engine fins after pair valve removal - 2000 Suzuki VZ800V Tue May 14, 2013 7:41 pm | |
| Nice job! it looks a lot better | |
| Subject: Re: Polished engine fins after pair valve removal - 2000 Suzuki VZ800V Tue May 14, 2013 8:25 pm | |
| Here's a pic I took this morning after I cleaned the engine. You can see how the polished/brushed fins really stand out now. | |
| Subject: Re: Polished engine fins after pair valve removal - 2000 Suzuki VZ800V Tue May 14, 2013 9:56 pm | |
| Beautiful job | |
| Subject: Re: Polished engine fins after pair valve removal - 2000 Suzuki VZ800V Tue May 14, 2013 10:12 pm | |
| - AmericanJambo wrote:
- Here's a pic I took this morning after I cleaned the engine. You can see how the polished/brushed fins really stand out now.
You've done a great job there Like you say, It really stands out and shows the top half of the engine off! | |
| Subject: Re: Polished engine fins after pair valve removal - 2000 Suzuki VZ800V Tue May 14, 2013 10:15 pm | |
| | | shadycowboy Member
| Subject: Re: Polished engine fins after pair valve removal - 2000 Suzuki VZ800V Tue May 14, 2013 11:05 pm | |
| awesome > off to homebase. Closed. Feck | |
| Subject: Re: Polished engine fins after pair valve removal - 2000 Suzuki VZ800V Thu May 16, 2013 6:50 pm | |
| That looks fab, great jobe done. The simple things obviously can make a huge difference | |
| Subject: Re: Polished engine fins after pair valve removal - 2000 Suzuki VZ800V | |
