 DIY Active TRE installation.
7 posters
DIY Active TRE installation. Empty
PostSubject: DIY Active TRE installation.   DIY Active TRE installation. Icon_minitimeSat May 31, 2014 3:59 pm
The connectors I ordered for the GPS (Gear Position Sensor) arrived today, and I build the active TRE circuit right away.
The info for this mod was collected on the internet from DIY-Smart TRE thread at motorcycleforums and Steve's TL1000S pages, thx to Steve and MantiZ68.
Parts needed:
6.8 Kohm resistor
47 Kohm resistor
BC547 or similar NPN transistor
Sumitomo HM 090-6 connectors to fit the GPS sensor.
I had the resistors and transistor in the drawer and the connectors I ordered from www.cycleterminal.com
The small circuit tricks the ECU into thinking the bike is always in 5th gear, thus eliminating the timing retard Suzuki has programmed into the ECU in 1st and 2nd gear.
It still has the normal timing when in neutral.
The circuit can be made on a small breadboard and placed in a box, but I just made it birds nest style, and wrapped it in self vulcanizing tape to protect it from moisture.
It gives a bit more grunt in 1st and 2nd gear, and I think it is worth doing for the small money and effort.
Schematic of the circuit.
DIY Active TRE installation. TRE_schematic
The white connector is for the GPS.
DIY Active TRE installation. IMAGE_18
The black, blue and pink wires are for the GPS.
DIY Active TRE installation. IMAGE_19
Small simple 3 components circuit.
DIY Active TRE installation. IMAGE_20
DIY Active TRE installation. IMAGE_21
Heat shrink around the exposed wires.
DIY Active TRE installation. IMAGE_22
Entire circuit and wires wrapped in self vulcanizing tape.
DIY Active TRE installation. IMAGE_23
Zip tied in place.
DIY Active TRE installation. IMAGE_24
PostSubject: Re: DIY Active TRE installation.   DIY Active TRE installation. Icon_minitimeSat May 31, 2014 4:16 pm
good job Kim nice and neat  DIY Active TRE installation. 3005623951
PostSubject: Re: DIY Active TRE installation.   DIY Active TRE installation. Icon_minitimeSat May 31, 2014 5:40 pm
Very nice job! Very neat and tidy too  DIY Active TRE installation. 2170595768
PostSubject: Re: DIY Active TRE installation.   DIY Active TRE installation. Icon_minitimeSat May 31, 2014 5:56 pm
Way above my head but I know some will find it very helpful, your a clever guy  DIY Active TRE installation. 3322349030
PostSubject: Re: DIY Active TRE installation.   DIY Active TRE installation. Icon_minitimeSat May 31, 2014 7:37 pm
Well in there Kim, good job done.  DIY Active TRE installation. 3498837457
kardax
kardax
PostSubject: Re: DIY Active TRE installation.   DIY Active TRE installation. Icon_minitimeThu Jun 12, 2014 4:23 pm
Hi,
about TRE, I just bought and installed Healtech's GIpro with ATRE, using it with setting 4, as adviced by instructions, so the question is, am I supposed to notice something?
I mean, I have tried setting TRE off and on, doing hard accelerations, and I do not notice any difference whether it's on or off.
So, maybe the effect of TRE might be quite small, that I just haven't noticed it yet, maybe because I have not done lot's of maximum accelerations, maybe I'll notice the difference later. Or maybe 2005 M800 does not have Timing Retard?
I'm a bit confused now, since I have read lots of experiences about how good thing TRE is on our bikes, so any ideas?
How have you actually measured, that how much TRE affects, or has all just used butt-dyno ? DIY Active TRE installation. 852880
PostSubject: Re: DIY Active TRE installation.   DIY Active TRE installation. Icon_minitimeThu Jun 12, 2014 7:44 pm
I did not measure anything and think it improved 1st and 2nd gear.
Maybe I'll try to remove it again to I test it.
PostSubject: Re: DIY Active TRE installation.   DIY Active TRE installation. Icon_minitimeThu Jun 12, 2014 9:15 pm
Daves post when he fitted one link
mick9264
mick9264
PostSubject: Re: DIY Active TRE installation.   DIY Active TRE installation. Icon_minitimeSun Jun 29, 2014 8:12 pm
Hi, do you know if the values for fourth gear are the same on a 2011 m800 please? this is a great bit of kit and looks really straightforward to make, I am used to having a lot more power on my bikes so any improvements will be welcome. thanks in advance, Mick
» How do you make an active link to another thread?
» * Suzuki C800, Healtech FI Pro (Installation video and instructions) *
» aftermarket speedometer installation
» Highway Hawk Turndowns Installation
» Redneck installation of grasshopper Back rest
DIY Active TRE installation. Icon_minitimeby Badger Tue Oct 22, 2024 1:36 pm
DIY Active TRE installation. Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:38 am
DIY Active TRE installation. Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
DIY Active TRE installation. Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
DIY Active TRE installation. Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
DIY Active TRE installation. Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
DIY Active TRE installation. Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
DIY Active TRE installation. Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
DIY Active TRE installation. Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
DIY Active TRE installation. Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
DIY Active TRE installation. Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
DIY Active TRE installation. Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
DIY Active TRE installation. Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
DIY Active TRE installation. Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
DIY Active TRE installation. Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
DIY Active TRE installation. Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
DIY Active TRE installation. Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
DIY Active TRE installation. Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
DIY Active TRE installation. Icon_minitimeby flying1 Wed Jul 31, 2024 1:59 pm
DIY Active TRE installation. Icon_minitimeby gary,, Fri Jul 12, 2024 2:30 pm
