| Exhaust for VL800 | |
+4captain crash simbo Lowey TwinDad 8 posters | Author | Message |
TwinDad Member
| Subject: Exhaust for VL800 Tue Jun 10, 2014 6:25 pm | |
| Hi, looking for loader pipes for my 2005 vl800, standard are ok but just bland. Looking for something that stands out and louder? Looking for something from UK as import tax is a killer. Also will I have to remap or adjust fuel injection Many thanks George Ps. I was the guy that asked about the brakes, you were right brakes are fine just not used to one disc and rear drum thanks. As you can see now own vl800. | |
| | | Lowey Valued Member
| Subject: Re: Exhaust for VL800 Tue Jun 10, 2014 6:35 pm | |
| Vance and Hines Cruzers sound really nice on the Intruders, many members have got these fitted on their bikes. If you only change the exhaust the ECU should manage the change on a fuel injected bike. | |
| Subject: Re: Exhaust for VL800 Tue Jun 10, 2014 7:09 pm | |
| - Lowey wrote:
- Vance and Hines Cruzers sound really nice on the Intruders, many members have got these fitted on their bikes. If you only change the exhaust the ECU should manage the change on a fuel injected bike.
Have a look in the exhaust data base to check out pics and video's of quite a few exhausts. video's Visual | |
| Subject: Re: Exhaust for VL800 Tue Jun 10, 2014 7:54 pm | |
| As Jeff said if its only the exhaust that is being changed and the air filter is left as stock then the FI module will be fine with it. I have only personaly heard the V&H Cruizers on an Intruder & they sound great but sound of pipes is very personal thing with pipes, one mans music is another mans noise | |
| Subject: Re: Exhaust for VL800 Tue Jun 10, 2014 8:44 pm | |
| Fuel injection will cope with only one of the two (exhaust or air-filter) being changed without a second thought. As for the pipes, I agree with Crash, they are very personal to the listener. However saying that though, I have the Cruzer's and love them. The only pipes I have heard better than them are Sim's V&H Pro-pipes, now the are beautiful, just beautiful, music to the ear's. | |
| Subject: Re: Exhaust for VL800 Tue Jun 10, 2014 9:31 pm | |
| | | TwinDad Member
| Subject: Re: Exhaust for VL800 Tue Jun 10, 2014 10:18 pm | |
| Many thanks guys will look at pics and videos. Not looking for them to play music just a loud rumble! Thanks G | |
| Subject: Re: Exhaust for VL800 Tue Jun 10, 2014 10:46 pm | |
| - TwinDad wrote:
- Many thanks guys will look at pics and videos. Not looking for them to play music just a loud rumble!
Thanks G If it's a loud rumble your after? I'd go V&H Cruzers or Jardine Rumblers, very similar pipe in looks and sound, Big Shots sound good too! I like the longer pipe look so went for the Pro Pipe which sounds good with good length, I also have the Straight shots which look equally good IMO but the sound is a bit farty in comparison to the others. It's all down to personal taste and budget at the end of the day, Happy pipe choosing | |
| | | TwinDad Member
| Subject: Re: Exhaust for VL800 Wed Jun 11, 2014 12:53 pm | |
| Sim, and the rest, many thanks guys think I'll look at the V&H cruisers they seem to be the look I am after. Many thanks G | |
| | | TwinDad Member
| Subject: Re: Exhaust for VL800 Thu Jun 26, 2014 2:35 pm | |
| Hi, well gone and done it got a cruzer exhaust on way. Could anyone tell me if it comes with the air sensor plug or do I have to get it drilled and welded. I know there is a thread about the size of the plugs etc just can't find it. Thanks | |
| | | Lowey Valued Member
| Subject: Re: Exhaust for VL800 Thu Jun 26, 2014 4:21 pm | |
| It probably will not come with the lamba sensor, but you can have it drilled to fit one or you can have small eliminator plug fitted to keep the FI light off. I'm sure you will not regret your choice.
Just to add to this about the lamba sensor you can find all the information about this in the exhaust section. | |
| Subject: Re: Exhaust for VL800 Thu Jun 26, 2014 5:07 pm | |
| George - boss is 12mm 1.25 pitch LINK | |
| | | TwinDad Member
| Subject: Re: Exhaust for VL800 Fri Aug 22, 2014 3:31 pm | |
| At last got my V&H exhaust more excited than a fat kid in a sweet shop. How easy was it to fit, so easy only took me an hour ish! So pleased really looks the dogs! Sounds sweet too, thanks again for all the advice guys! Only thing has a backfire on throttle blip, I know don't blip it then lol. Going to get a blanking plug for co2 plug Pictures to follow here is one of stock exhaust before | |
| | | TwinDad Member
| | | | DocSjulle Hero Globs
| Subject: Re: Exhaust for VL800 Fri Aug 22, 2014 4:21 pm | |
| Looks so shiny inside and out when brand new You might need to block of the PAIR valve to get rid of the backfire. Why not just clip the pin23 wire on the ECU to disable the O2 sensor completely ? | |
| Subject: Re: Exhaust for VL800 Fri Aug 22, 2014 4:37 pm | |
| Very Nice!! Welcome to the Deep Rumble of aftermarket pipes | |
| | | TwinDad Member
| Subject: Re: Exhaust for VL800 Fri Aug 22, 2014 7:03 pm | |
| DucSjulle what's the pair valve? See you have power Pro tuner too is that a necessary mod what else does it do? G | |
| Subject: Re: Exhaust for VL800 Fri Aug 22, 2014 7:15 pm | |
| The PAIR valve is an emission controlling device, letting a small amount of air into the exhaust when you lift of the throttle, to ignite unburned gas. See this thread: https://www.suzuki800.com/t435-pair-valve-leave-it-or-lose-it-c800-c50-m800-m50-vz800?highlight=Pair+valveAnd you do not need a FI controller when you only change the exhaust. When I got my bike, it had the Cruzers, standard airfilter, and the pin23 wire cut, and drove just fine. You only need the Fi tuner if you decide to get a free flowing air filter too, to adjust the amount of fuel to the increased airflow from the filter.
| Subject: Re: Exhaust for VL800 Fri Aug 22, 2014 7:18 pm | |
| Nice pipes George, .....& the bonus being they were easy to fit ! | |
| | | TwinDad Member
| Subject: Re: Exhaust for VL800 Tue Aug 26, 2014 9:15 am | |
| Just spoke to mike at custom Crusers, says they can do lambda sensor boss for exhaust about £50 plus ups delivery. Really knowledgeable guy, got blanking plug for now. Anyone know of anyone closer to me SW London that does it Thanks G | |
| Subject: Re: Exhaust for VL800 Tue Aug 26, 2014 9:26 am | |
| - TwinDad wrote:
- Just spoke to mike at custom Crusers, says they can do lambda sensor boss for exhaust about £50 plus ups delivery. Really knowledgeable guy, got blanking plug for now. Anyone know of anyone closer to me SW London that does it
Thanks G Sorry I don't know anyone closer but your right 'Mike' is a very knowledgeable man. | |
| | | TwinDad Member
| Subject: Re: Exhaust for VL800 Tue Aug 26, 2014 9:38 am | |
| So a job for winter then, thanks Dave. | |
| | | TwinDad Member
| Subject: Re: Exhaust for VL800 Tue Aug 26, 2014 9:42 am | |
| Looking at doing PAIR valve mod, got kit coming from US, read thread so, may try that to stop backfire. If not then as above will get Mike to weld boss on rear pipe and refit sensor. | |
| Subject: Re: Exhaust for VL800 Tue Aug 26, 2014 8:13 pm | |
| I like the sound of the " backfire" although I think its far from the noise of a back fire more of a healthy rumble | |
| | | TwinDad Member
| Subject: Re: Exhaust for VL800 Thu Aug 28, 2014 4:33 pm | |
| Sorted backfire, the bike didn't have gaskets fitted at all, fitted gaskets and now all good still sounds EPIC! Great choice and advice from site THANKS! G | |
| Subject: Re: Exhaust for VL800 Thu Aug 28, 2014 5:29 pm | |
| Glad you got it sorted George EPIC! | |
| | | TwinDad Member
| Subject: Re: Exhaust for VL800 Thu Aug 28, 2014 5:49 pm | |
| Thanks Sim had to sort it, was kidding self was really load! LOL G | |
| | | | Sponsored content
| Subject: Re: Exhaust for VL800 | |
