 VX800 final drive
6 posters
VX800 final drive Empty
PostSubject: VX800 final drive   VX800 final drive Icon_minitimeFri Apr 03, 2015 9:33 pm
I know some have you have changed the shaft etc on your 800's to lower the rpm etc at cruising speed, can the same be done for my VX800? I have just been browsing ebay and thought would the final drive from a GSX1100G fit my VX? Fit a front wheel with twin discs and rear wheel as well with all the bits!!
PostSubject: Re: VX800 final drive   VX800 final drive Icon_minitimeFri Apr 03, 2015 9:59 pm
I've no idea Andrew, you'd need both bikes to compare the parts you'd be interchanging?, is the vx final drive much different to the vs1400 drive? the vx looks similar to the vl800 drive.
dennis chapman
dennis chapman
PostSubject: Re: VX800 final drive   VX800 final drive Icon_minitimeSat Jan 16, 2016 1:14 am
my vx800 rear drive has gone south will a vl800 rear drive fit or anything at all, busted rear and off the road thanks
PostSubject: Re: VX800 final drive   VX800 final drive Icon_minitimeSat Jan 16, 2016 10:07 am
They look similar but I'm not sure they'd be a direct swap? There's a used VX drive on ebay au now, loads on ebay.com too, why take the risk.
www.ebay.com.au/itm/1990-Suzuki-VX800-Final-Drive-Assembly-with-Drive-Shaft-Output-Differential-/191777831668?hash=item2ca6d97af4:g:g0IAAOSwzOxUYlZy
www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR0.TRC0.H0.Xsuzuki+vx800+final+drive.TRS0&_nkw=suzuki+vx800+final+drive&_sacat=0
dennis chapman
dennis chapman
PostSubject: Re: VX800 final drive   VX800 final drive Icon_minitimeSat Jan 16, 2016 2:17 pm
hi,thanks simbo vx800s are fairly thin on the ground here in oz i found a vx rear drive they want $325au but there are plenty of vl's being wrecked.looking up spare parts numbers the different numbers are the case and bearing stopper.the gears bearings seals etc are the same.i suspect the three studs where it bolts to the swing arm may have different spacing.there is a thread on this forum about fitting a vs1400 rear to get higher gearing and he had to alter the swing arm holes.the one on ebay is half the price thanks very much for your input
The author of this message was banned from the forum - See the message
PostSubject: Re: VX800 final drive   VX800 final drive Icon_minitimeTue Jun 28, 2016 2:31 am
If I'm understanding you correctly, are you asking if fitting a VS700/800 final drive will lower your revs ?  Sure someone (Dave or Sim) will correct me, but you need to be fitting the VS1400 diff unit (mated with the drive shaft from an 800) to reduce the revs.  I can't see that fitting the diff from a different model 800 would have an appreciable effect on the gearing.  You need to mill the 800 shaft down slightly, as the 1400 shaft is not long enough - if you have a look at the photographs of page one of Dave's "How To" thread, you'll see the difference in the lengths.
PostSubject: Re: VX800 final drive   VX800 final drive Icon_minitimeTue Jun 28, 2016 2:19 pm
Dave the unfortunate reply to the question is that the  VS700 or 800 is totally different from the VL range as you & I have & the VS1400 diff assembly will not fit the VS7/800 models as sayhello has been informed before on the site before.
PostSubject: Re: VX800 final drive   VX800 final drive Icon_minitimeSun Jul 03, 2016 7:20 pm
There's a few diffs on ebay at the moment & a few 800 diffs complete with the shaft - no 800 shafts only though
PostSubject: Re: VX800 final drive   VX800 final drive Icon_minitimeSun Jul 03, 2016 10:33 pm
How To  - however - this is only applicable to the VL models.  It may be better for you ask someone in a VX forum as they'll have had more experience with VX's.  Sorry I can't be of any more assistance than that
VX800 final drive
» Final drive
» Suzuki VS 1400 Final Drive Mod
» Would a GSX1100G final drive fit a 800??
» vs 1400 final drive in a vs 800
» SAE90 final drive oil?
VX800 final drive Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
VX800 final drive Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
VX800 final drive Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
VX800 final drive Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
VX800 final drive Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
VX800 final drive Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
VX800 final drive Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
VX800 final drive Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
VX800 final drive Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
VX800 final drive Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
VX800 final drive Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
VX800 final drive Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
VX800 final drive Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
VX800 final drive Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
VX800 final drive Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
VX800 final drive Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
VX800 final drive Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
VX800 final drive Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
VX800 final drive Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
VX800 final drive Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
