| Worth changing unusued oil? | |
EazyDuz Member
| Subject: Worth changing unusued oil? Fri Apr 27, 2018 7:39 pm | |
| Last year I changed the oil and filter, probably did about 300 miles then the bike went into storage for a year. During that time It was started and idled for 20 minutes probably 4 times total. Since the engine and oil hasnt had much use at all, do I need to change it now at the start of the season, or can I run it on the oil in there until November and then change it. Thanks | |
| Subject: Re: Worth changing unusued oil? Fri Apr 27, 2018 7:46 pm | |
| I wouldn't | |
| Subject: Re: Worth changing unusued oil? Fri Apr 27, 2018 8:51 pm | |
| It should be fine but 4l of semi is just over £20 so why not change it?? | |
| Subject: Re: Worth changing unusued oil? Fri Apr 27, 2018 9:59 pm | |
| - v-twin wrote:
- It should be fine but 4l of semi is just over £20 so why not change it??
Because £20's roughly the cost of 4 Full Breakfasts Would you go in the cafe tomorrow and order 4 full plates then scrape them in the bin because you didn't get a fork straight away? | |
| Subject: Re: Worth changing unusued oil? Fri Apr 27, 2018 10:08 pm | |
| I have been in a few cafe's that I would have said yes to that question | |
| Subject: Re: Worth changing unusued oil? Fri Apr 27, 2018 11:16 pm | |
| Subject: Re: Worth changing unusued oil? Sat Apr 28, 2018 8:53 am | |
| Oil & filter should be fine for this season | |
| | | ardie Valued Member
| Subject: Re: Worth changing unusued oil? Sat Apr 28, 2018 1:39 pm | |
| I change oil n filter every year but at just 300 miles couldnt bring myself to drain it | |
| | | bagtoracer68 Member
| Subject: Re: Worth changing unusued oil? Sat Apr 28, 2018 5:52 pm | |
| It'll be fine to run for the year. Oil life is based on time on the clock, (running), and your oil sounds like it only has just over an hour on it... | |
| Subject: Re: Worth changing unusued oil? | |
