 pair valve & o2 sensor FI light cure
2 posters
tubemonster
tubemonster
pair valve & o2 sensor FI light cure  Empty
PostSubject: pair valve & o2 sensor FI light cure    pair valve & o2 sensor FI light cure  Icon_minitimeFri Nov 25, 2011 5:19 am
pair valve & o2 sensor FI light cure  4070287859 Hi, just taken pair off as per Moccasins site (awesome by the way)..anyhow,I got rid of the ugly lump on the side by linking up the two pipes with one tube length and a 15mm top length of a s/steel drill bit of the right diameter blocking it,a bit more solid than the golf tee recommended, but the same deal!..Problem is the fuel injection warning light kept coming on a week later, i`ve done a quite a few mods around the same time so after a lot of headscratching and tinkering I took it to my local bike shop who pluged in the laptop. Turned out the solinoid from the pair valve had packed up,fitted a resistor in its place and all good..
PAIR SOLINOID SENSOR; 0.5W metalfilm 4K7 oham resistor to fool the FI, soldered between the cables that used to go to solinoid (saves space too) there was carbon and ceramic resistors in the shop which I also got as there real cheap..dont know which is best? metal film was the first fitted,worked,so stuck with it (sure someone will advise)
On my quest to get rid of the dreaded FI light I also found out about an easy fix for the O2 sensor, not tried it myself as I pulled the O2 pin at the ecu, but if your O2 sensor is giving you problems and you dont want to drill a hole in your after market pipes or route around your ECU. I was told by bike mechanic, a 330k resistor in place of the sensor will keep the computer happy.Personally I wouldnt do this without a power commander/cobra ect to run the show. Perhaps someone`s tried it and can comment?
icetechaus
icetechaus
PostSubject: Re: pair valve & o2 sensor FI light cure    pair valve & o2 sensor FI light cure  Icon_minitimeFri Nov 25, 2011 11:17 am
Tubemonster
For what you are doing you could use carbon or metal film resistor it won't make any real difference. Main difference for this purpose is tolerance and package size and in this case it won't make any difference.
» Pair valve removal kit??
» PAIR Valve Blanking Kit Recommendations Please
» Sachs 800 PAIR valve removal
» Cheap Pair Valve Removal 98 VZ800
» * Pair Valve, leave it or lose it C800 / C50 / M800 / M50 / VZ800 *
pair valve & o2 sensor FI light cure  Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
pair valve & o2 sensor FI light cure  Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
pair valve & o2 sensor FI light cure  Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
pair valve & o2 sensor FI light cure  Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
pair valve & o2 sensor FI light cure  Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
pair valve & o2 sensor FI light cure  Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
pair valve & o2 sensor FI light cure  Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
pair valve & o2 sensor FI light cure  Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
pair valve & o2 sensor FI light cure  Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
pair valve & o2 sensor FI light cure  Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
pair valve & o2 sensor FI light cure  Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
pair valve & o2 sensor FI light cure  Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
pair valve & o2 sensor FI light cure  Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
pair valve & o2 sensor FI light cure  Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
pair valve & o2 sensor FI light cure  Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
pair valve & o2 sensor FI light cure  Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
pair valve & o2 sensor FI light cure  Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
pair valve & o2 sensor FI light cure  Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
pair valve & o2 sensor FI light cure  Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
pair valve & o2 sensor FI light cure  Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
