 Fitted new indicators & leds to m800
6 posters
Guest
Guest
Fitted new indicators & leds to m800 Empty
PostSubject: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeSun Jan 29, 2012 9:36 pm
Indicators fitted to rad cover, and LED's glued to lever's as secondary indicators
Fitted new indicators & leds to m800 Dscf0116
Fitted new indicators & leds to m800 Dscf0115
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeSun Jan 29, 2012 9:54 pm
Looks really great pete I love the idea of adding the leds as extra wired in indicators, thats another one for my to do list Fitted new indicators & leds to m800 276246
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeSun Jan 29, 2012 10:00 pm
Looking good Pete very clever idea with the leds mate Fitted new indicators & leds to m800 3492671266 Fitted new indicators & leds to m800 3322349030 Fitted new indicators & leds to m800 881924
greasymike
greasymike
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeFri Feb 03, 2012 5:37 pm
did you have to install a resistor in the elec system for the LED's??
CycleBiker
CycleBiker
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeFri Feb 03, 2012 5:41 pm
Nice work!
I'm guessing the led pods had the resistor built in for 12 volts.
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeFri Feb 03, 2012 6:03 pm
No resister required, the led lights are just working as extras along side the new standard after-market indicators that have been fitted!
Guest
Guest
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeFri Feb 03, 2012 7:37 pm
As Dave said, there is know need for a resistor C/B, as they are wired into and work in conjunction with the correct voltage / wattage indicators they flash at the same speed , but they do have a polarity ,so will only work when wired live to live neutral to neutral Fitted new indicators & leds to m800 184121345 .
CycleBiker
CycleBiker
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeFri Feb 03, 2012 8:54 pm
So you wired them in series with the turn signal bulbs using the existing bulb resistance as your control resistor?
Guest
Guest
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeFri Feb 03, 2012 10:43 pm
You got it mate Wink
exile
exile
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeSat Feb 04, 2012 6:24 pm
Have you MOT'd it like that ?? Just a thought but.... surely the indicators are obscured by the front fork legs?? Don't wanna fall foul of the construction an use regs do we ?!!!
ps Don't tell F%"$in Bennetts
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeSat Feb 04, 2012 6:36 pm
Technically the tester can refuse the MOT if one or more directional indicators are obscured, However if he is that much of a cock it would be the last time I ever went their!
With my scrambler I had no indicators fitted at all but if you have no indicators you must have no rear pegs fitted either if the vehicle can exceed 30mph!
Guest
Guest
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeSat Feb 04, 2012 7:05 pm
Its not due its first MOT until 2014, but i will move them for that, and your right they are obscured by the fork to anything directly in front up until about 250 yards, but they start to come into view to on coming traffic at about 18 degrees (hence the LEDs), but in the evening and at night the LEDs are brighter than them anyway, I'm gunna av to ride like this Fitted new indicators & leds to m800 1792677282 .
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeSat Feb 04, 2012 7:07 pm
Yeah but you also have LED's on the front as well, so alls good
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeSat Feb 04, 2012 7:14 pm
Right I have just got this from the MOT criteria
MOT criteria wrote:
The precise position and angle of visibility of direction indicators are not part of this inspection, but they must be on each side of the longitudinal axis of the machine
So they will not fail on there positioning at all, so leave them where they are Fitted new indicators & leds to m800 3498837457
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeSat Feb 04, 2012 7:20 pm
You do have your uses Mr I Fitted new indicators & leds to m800 184121345 ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, Fitted new indicators & leds to m800 641964
CycleBiker
CycleBiker
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeSat Feb 04, 2012 7:26 pm
Man, you guys are sure concerned about those MOT inspectors.
I took a BMW R100 for a state inspection here. I had bought it wrecked and done quite a bit of work on it so when I get home the wife asked if the inspector looked at it real closely when he inspected it. Oh yeah I said, he stared at it for at least a minute longer than he usually does when he looks outside at a bike through his office window.
This doesn' happen anymore though 'cos they now have to photograph the odometer and frame number and licence plate so the old geezer has to get off his butt for his $10.
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeSat Feb 04, 2012 7:34 pm
Well it aint £6.32p here its £29.65p and they make sure the bike is safe to be on the road
greasymike
greasymike
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeSat Feb 04, 2012 11:19 pm
don't have to worry here bout state inspections..Kansas don't have'em..only inspection is when you buy a vehicle out of state and then the title and vin needs looked at..
CycleBiker
CycleBiker
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeSun Feb 05, 2012 4:36 am
I know they are pretty tough on bikes in the UK. My neice had to fork over a bundle to have a horsepower limiter fitted to her GS500! This is her renting a Harley in Vegas:
Fitted new indicators & leds to m800 Sarah
Badger
Badger
PostSubject: Re: Fitted new indicators & leds to m800   Fitted new indicators & leds to m800 Icon_minitimeSun Feb 05, 2012 10:58 am
That's a lovely pic CB, how is it so bright?
............ Ahhh ... SUNSHINE. I forgot about that. Fitted new indicators & leds to m800 3629380964
» Fitted new horn under Right Side Panel - M800
» VL Bars Fitted To A Suzuki M50 / M800
» New Grips Fitted To Suzuki M800 / M50
» Scorpion end cans fitted to my M800
» Renegade Sissy Bar and Rack Fitted on M800
Fitted new indicators & leds to m800 Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Fitted new indicators & leds to m800 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Fitted new indicators & leds to m800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Fitted new indicators & leds to m800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Fitted new indicators & leds to m800 Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Fitted new indicators & leds to m800 Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Fitted new indicators & leds to m800 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Fitted new indicators & leds to m800 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Fitted new indicators & leds to m800 Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Fitted new indicators & leds to m800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Fitted new indicators & leds to m800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Fitted new indicators & leds to m800 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Fitted new indicators & leds to m800 Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Fitted new indicators & leds to m800 Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Fitted new indicators & leds to m800 Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Fitted new indicators & leds to m800 Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Fitted new indicators & leds to m800 Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Fitted new indicators & leds to m800 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Fitted new indicators & leds to m800 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Fitted new indicators & leds to m800 Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
