 Horn Not working on M800
3 posters
chrisalang
Newbie
chrisalang
Horn Not working on M800 Empty
PostSubject: Horn Not working on M800   Horn Not working on M800 Icon_minitimeMon Mar 19, 2012 7:40 am
The horn on my Intruder has stopped working. I have removed it and tested and it is fine so it is the wiring. The horn push switch appears to be working with 12V at input and when pushed 12V at the output. On the connections to the horn there is a constant 12V but no earth. Is the horn activated via earth activation using a relay? If so where is the relay? I will change the stock horn for a better one but I need to get the wiring working first. Any help appreciated.
PostSubject: Re: Horn Not working on M800   Horn Not working on M800 Icon_minitimeMon Mar 19, 2012 9:05 am
Have you checked the continuity of the earth. The horn does not have a relay as it doesnt pull hardly any power
There is a wiring diagramme for your bike in the pdf manual in the maintenance section, hope that helps Horn Not working on M800 184121345
PS. Pop in to the C'mon in and say hello section to introduce yourself as the site rules are that members must introduce themselves before posting. If an admin spots this thread without an introduction it will be deleted (I have seen that happen).
ippikin
ippikin
PostSubject: Re: Horn Not working on M800   Horn Not working on M800 Icon_minitimeMon Mar 19, 2012 11:16 am
This happened to me.... the horn just stopped working. If there is continuity at the switch (check with a mulitmeter) then I would ditch the stock horn (as it's so pathetic) and either fit a Stebel Nautilus as per Mr Intruder, see LINK. Or you could do what I did and fit a new horn under the R side panel. See LINK
» Horn on M800 stopped working
» Horn Change on M800
» Fitted new horn under Right Side Panel - M800
» Horn and distribution box
» Brake light not working.
Horn Not working on M800 Icon_minitimeby Jack70 Mon Nov 18, 2024 1:35 pm
Horn Not working on M800 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 1:19 pm
Horn Not working on M800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 3:26 pm
Horn Not working on M800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 3:03 pm
Horn Not working on M800 Icon_minitimeby wayne phillips Mon Nov 04, 2024 10:56 pm
Horn Not working on M800 Icon_minitimeby Reidzzz Wed Oct 09, 2024 3:32 am
Horn Not working on M800 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 10:13 am
Horn Not working on M800 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 5:44 pm
Horn Not working on M800 Icon_minitimeby watsonchuck1 Sat Sep 21, 2024 11:00 pm
Horn Not working on M800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 7:59 pm
Horn Not working on M800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 7:56 pm
Horn Not working on M800 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 1:51 pm
Horn Not working on M800 Icon_minitimeby Badger Mon Sep 02, 2024 6:44 am
Horn Not working on M800 Icon_minitimeby henrikndk Thu Aug 29, 2024 1:29 am
Horn Not working on M800 Icon_minitimeby FrostyMug Sun Aug 25, 2024 4:07 pm
Horn Not working on M800 Icon_minitimeby Doc Cox Thu Aug 22, 2024 3:45 pm
Horn Not working on M800 Icon_minitimeby chrismason68 Fri Aug 16, 2024 9:57 am
Horn Not working on M800 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 12:23 pm
Horn Not working on M800 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 10:44 am
Horn Not working on M800 Icon_minitimeby Popshot Tue Aug 13, 2024 4:30 pm
