 New Bars................. 2013 M800
4 posters
Kfc1404
Kfc1404
New Bars................. 2013 M800 Empty
PostSubject: New Bars................. 2013 M800   New Bars................. 2013 M800 Icon_minitimeMon Mar 03, 2014 8:30 pm
Well, completely failed in my attempt to change my handlebars today. Unbeknown to me, on the latest model of M800, the yoke has inserts pressed into the yoke that are designed to reduce vibration, i.e. ferrules encased in rubber. This severely reduces the options available for changing the risers.
I haven't given up, yet....
PostSubject: Re: New Bars................. 2013 M800   New Bars................. 2013 M800 Icon_minitimeMon Mar 03, 2014 8:33 pm
Oh no that's a bastard, Will have to look into that.  New Bars................. 2013 M800 474255
PostSubject: Re: New Bars................. 2013 M800   New Bars................. 2013 M800 Icon_minitimeMon Mar 03, 2014 8:56 pm
Good on ya Graham,   New Bars................. 2013 M800 184121345  seems stupid that
PostSubject: Re: New Bars................. 2013 M800   New Bars................. 2013 M800 Icon_minitimeMon Mar 03, 2014 9:06 pm
Graham, I'm pretty sure the C800 has those inserts in the top yolk as well, My bandit does too, How does this restrict your choice of risers?
Kfc1404
Kfc1404
PostSubject: Re: New Bars................. 2013 M800   New Bars................. 2013 M800 Icon_minitimeMon Mar 03, 2014 9:42 pm
The bolt sizes on the aftermarket risers are much too big to fit into the inserts.
PostSubject: Re: New Bars................. 2013 M800   New Bars................. 2013 M800 Icon_minitimeMon Mar 03, 2014 10:04 pm
That's a bummer then  New Bars................. 2013 M800 474255 The stock bolts on the C risers are M12 and both sets of after market risers I've had for mine have been M10 and needed a sleeve fitting to pack them out to 12mm, What size bolts are they on the M model out of curiosity?
PostSubject: Re: New Bars................. 2013 M800   New Bars................. 2013 M800 Icon_minitimeTue Mar 04, 2014 8:29 am
When I originally fitted my risers I just made sure they were correctly placed as I reached the point of torquing down. Maybe I am just a bit to lazy compared to some.  New Bars................. 2013 M800 852880
Kfc1404
Kfc1404
PostSubject: Re: New Bars................. 2013 M800   New Bars................. 2013 M800 Icon_minitimeTue Mar 04, 2014 9:21 am
I'm sure mine are M12 too, problem I've found is that all the aftermarket risers seem to have much larger bolts. I have purchased some now that you can put a smaller bolt in so, I will fit the largest that the sleeve will accommodate. The only consideration is how to correctly line up the risers if the bolt is not captive. The bars need to sit in the risers absolutely perfectly and if I use an Allen headed bolt I risk the riser twisting when tightening up the bolt, it only has to move a fraction before the risers would not be aligned. I did consider getting the bolt spot welded in the riser body but, of course they are aluminium and the bolt steel! I'll find a way I'm sure!
PostSubject: Re: New Bars................. 2013 M800   New Bars................. 2013 M800 Icon_minitimeTue Mar 04, 2014 5:48 pm
I just wrapped some electrical tape around the bolts to give them the same diameter as the originals at first Graham, That gets them central in the yoke and stops them twisting, Then I got 2, M10 Rawl bolts and took the sleeve off and cut them down to the thickness of the yoke and slid them over the bolt to pack it out to 12mm as a more solid result, although they seemed fine with tape packing them out.
Kfc1404
Kfc1404
PostSubject: Re: New Bars................. 2013 M800   New Bars................. 2013 M800 Icon_minitimeTue Mar 04, 2014 8:25 pm
I've got bars and risers from a '08 vl800 coming. I'm hoping i can make them fit!
Regards
Graham
PostSubject: Re: New Bars................. 2013 M800   New Bars................. 2013 M800 Icon_minitimeTue Mar 04, 2014 9:27 pm
I cant see any reason why not, unless there was a triple tree change on later models. Cant see it tho, good luck  New Bars................. 2013 M800 184121345
» Changing the bars from M800 ones to cruiser bars
» VL Bars Fitted To A Suzuki M50 / M800
» Thinking of changing my bars on Suzuki M800
» Engine Bars Fitted .......... 2010 Suzuki M800
» Where do your Crash Bars mount? for Suzuki M800 2008 (VZ800)
New Bars................. 2013 M800 Icon_minitimeby MTB59 Yesterday at 6:29 pm
New Bars................. 2013 M800 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
New Bars................. 2013 M800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
New Bars................. 2013 M800 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
New Bars................. 2013 M800 Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
New Bars................. 2013 M800 Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
New Bars................. 2013 M800 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
New Bars................. 2013 M800 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
New Bars................. 2013 M800 Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
New Bars................. 2013 M800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
New Bars................. 2013 M800 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
New Bars................. 2013 M800 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
New Bars................. 2013 M800 Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
New Bars................. 2013 M800 Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
New Bars................. 2013 M800 Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
New Bars................. 2013 M800 Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
New Bars................. 2013 M800 Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
New Bars................. 2013 M800 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
New Bars................. 2013 M800 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
New Bars................. 2013 M800 Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
