 Damaged battery, repaired.
4 posters
Damaged battery, repaired. Empty
PostSubject: Damaged battery, repaired.   Damaged battery, repaired. Icon_minitimeSat Jan 03, 2015 10:06 pm
(Copied From Doc Cox's Virago Thread)
Decided today would be a good time to get the bike running, but one flat battery, so, out with the spare but some previous owner had badly damaged one of the contacts, now it was repair time
Damaged battery, repaired. SDC10050_zpsd2922876
just used a pair of pliers and took them off.
Damaged battery, repaired. SDC10051_zpsce7bff0b
Used a sharp wood chisel to remove the excess metal
Then very carefully drilled down the post tap a thread into it, managed to drill down about 3/4" which is more than enough for a stud to be fitted, this would be stronger then tapping the hole and fitting a bolt
Damaged battery, repaired. SDC10055_zpscc6a120c
First a primary tap followed up by a plug tap
Damaged battery, repaired. SDC10054_zpsa36cf464
Dave gave me this large syringe that is usefull for all sorts of jobs, one being blowing the swarf out of the tapped hole as it wasn,t a good idea to turn the battery upside down
Damaged battery, repaired. SDC10056_zpsd5938403
Found an Allen stud making it easy to screw in
Damaged battery, repaired. SDC10058_zps9fd382c0
One stud in place and ready for the cable, hope this is usefull to anyone in the same predicament,
Damaged battery, repaired. SDC10059_zps2ffca84f
Regards Doc Cox
PostSubject: Re: Damaged battery, repaired.   Damaged battery, repaired. Icon_minitimeSun Jan 04, 2015 12:13 am
oyili  - great bit of ingenuity !
PostSubject: Re: Damaged battery, repaired.   Damaged battery, repaired. Icon_minitimeSun Jan 04, 2015 8:19 am
Must say, I am always extremely impressed with Nigel's (Doc Cox's) constant ingenuity.
PostSubject: Re: Damaged battery, repaired.   Damaged battery, repaired. Icon_minitimeSun Jan 04, 2015 10:01 am
Recycling ilis  Damaged battery, repaired. 3498837457
PostSubject: Re: Damaged battery, repaired.   Damaged battery, repaired. Icon_minitimeSun Jan 04, 2015 5:03 pm
Brilliant bit of thinking there Doc, another bit of landfill and hard earned cash saved.
» Battery
» RR/Battery second opinion
» Dead Battery
» flat battery
» Lithium Battery
Damaged battery, repaired. Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Damaged battery, repaired. Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Damaged battery, repaired. Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Damaged battery, repaired. Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Damaged battery, repaired. Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Damaged battery, repaired. Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Damaged battery, repaired. Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Damaged battery, repaired. Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Damaged battery, repaired. Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Damaged battery, repaired. Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Damaged battery, repaired. Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Damaged battery, repaired. Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Damaged battery, repaired. Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Damaged battery, repaired. Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Damaged battery, repaired. Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Damaged battery, repaired. Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Damaged battery, repaired. Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Damaged battery, repaired. Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Damaged battery, repaired. Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Damaged battery, repaired. Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
