 Mirror rotates at higher speed.
7 posters
Mirror rotates at higher speed. Empty
PostSubject: Mirror rotates at higher speed.   Mirror rotates at higher speed. Icon_minitimeSat Jan 24, 2015 6:38 pm
I went for a blast ride out today and the left mirror started to rotate towards me, the arm did not move just the mirror but I cannot see anyway of tightening it, any ideas?
PostSubject: Re: Mirror rotates at higher speed.   Mirror rotates at higher speed. Icon_minitimeSat Jan 24, 2015 7:42 pm
Can your put a few drops of thread lock around the ball and work it in? when it sets it might stiffen it up a bit?
PostSubject: Re: Mirror rotates at higher speed.   Mirror rotates at higher speed. Icon_minitimeSat Jan 24, 2015 7:49 pm
I did think of that, I suppose if I add it and then go for a slow ride to make sure the mirror is in the correct position, if it then sets to hard and stops it from moving totally it would not matter, just checked online £40+ new each, ouch.
PostSubject: Re: Mirror rotates at higher speed.   Mirror rotates at higher speed. Icon_minitimeSat Jan 24, 2015 9:59 pm
Mine used to do that at about 80. Did not like the vibes at that speed so it was a way I knew to slow down!
PostSubject: Re: Mirror rotates at higher speed.   Mirror rotates at higher speed. Icon_minitimeSat Jan 24, 2015 10:03 pm
Built in speed limiter,(free of charge) no brainer there.
PostSubject: Re: Mirror rotates at higher speed.   Mirror rotates at higher speed. Icon_minitimeSun Jan 25, 2015 8:33 pm
Stock mirrors are non adjustable Sims idea sounds like a bloody good on. I would never of thought of that but if your going to do that clean the ball & joint properly. Take the mirror off and turn it upside down while using a cleaning fluid or spray, that should help it clean it out properly as it will be greasy & thread lock won't like that.
PostSubject: Re: Mirror rotates at higher speed.   Mirror rotates at higher speed. Icon_minitimeMon Jan 26, 2015 12:05 am
If you haven't got thread lock, I wonder if a drop of clear bathroom silicone sealant would do the trick?
PostSubject: Re: Mirror rotates at higher speed.   Mirror rotates at higher speed. Icon_minitimeMon Jan 26, 2015 7:36 am
I put a few drops of Blue Threadlock on it yesterday and worked it in, did not get the chance to out but I will report back when I do. Thanks for the advice.
PostSubject: Re: Mirror rotates at higher speed.   Mirror rotates at higher speed. Icon_minitimeThu Jan 29, 2015 7:00 pm
Blue tack or sticky back plastic should sort the job out, failing that I would use Bubble gum  Mirror rotates at higher speed. 3213823784
Glad its sorted Andrew  Mirror rotates at higher speed. 184121345
» Mirror Threads, Size?
» Wider Angle Mirror Upgrade
» Idle speed adjustment
» Gear ratio to top end speed.
» Front wheel speed sensor
Mirror rotates at higher speed. Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Mirror rotates at higher speed. Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Mirror rotates at higher speed. Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Mirror rotates at higher speed. Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Mirror rotates at higher speed. Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Mirror rotates at higher speed. Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Mirror rotates at higher speed. Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Mirror rotates at higher speed. Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Mirror rotates at higher speed. Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Mirror rotates at higher speed. Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Mirror rotates at higher speed. Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Mirror rotates at higher speed. Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Mirror rotates at higher speed. Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Mirror rotates at higher speed. Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Mirror rotates at higher speed. Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Mirror rotates at higher speed. Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Mirror rotates at higher speed. Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Mirror rotates at higher speed. Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Mirror rotates at higher speed. Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Mirror rotates at higher speed. Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
