 MOT Fail. Dead Relay? No Power
shadycowboy
7 posters
shadycowboy
shadycowboy
MOT Fail. Dead Relay? No Power Empty
PostSubject: MOT Fail. Dead Relay? No Power   MOT Fail. Dead Relay? No Power Icon_minitimeFri May 15, 2015 7:03 pm
So picked the bike up today from the garage. New tyres on. Sticks like glue. But thats another story.
Went to the MOT centre. Off bike, turned off. Usual look over by mechanic.
Back on Bike. Turned on, everything lights up, hit starter button. DEAD. Turned off. Turned on nothing, no power at all.
FAILED
Bike pushed up hill and back into Suzuki. I'd rather it was here at home to fix it but no choice at the time.
I just fitted new indicators and a new led relay would that have been the problem?
PostSubject: Re: MOT Fail. Dead Relay? No Power   MOT Fail. Dead Relay? No Power Icon_minitimeFri May 15, 2015 7:22 pm
Main Fuse?
shadycowboy
shadycowboy
PostSubject: Re: MOT Fail. Dead Relay? No Power   MOT Fail. Dead Relay? No Power Icon_minitimeFri May 15, 2015 7:30 pm
I don't even have the bike to check. :( Just looking reassurance from the members its not something major.
PostSubject: Re: MOT Fail. Dead Relay? No Power   MOT Fail. Dead Relay? No Power Icon_minitimeFri May 15, 2015 7:33 pm
Have all the electrics shut down, or just the engine/starter circuits ?
shadycowboy
shadycowboy
PostSubject: Re: MOT Fail. Dead Relay? No Power   MOT Fail. Dead Relay? No Power Icon_minitimeFri May 15, 2015 7:37 pm
All of them. Every last thing. Started fine at the garage. went about 90 seconds around the corner and. Dead.
PostSubject: Re: MOT Fail. Dead Relay? No Power   MOT Fail. Dead Relay? No Power Icon_minitimeFri May 15, 2015 8:02 pm
Battery died? I had that, and it was very sudden...
PostSubject: Re: MOT Fail. Dead Relay? No Power   MOT Fail. Dead Relay? No Power Icon_minitimeFri May 15, 2015 10:27 pm
Main fuse, as Sim says.
shadycowboy
shadycowboy
PostSubject: Re: MOT Fail. Dead Relay? No Power   MOT Fail. Dead Relay? No Power Icon_minitimeFri May 15, 2015 11:24 pm
Fingers crossed. I have a suspicion its the new relay though
PostSubject: Re: MOT Fail. Dead Relay? No Power   MOT Fail. Dead Relay? No Power Icon_minitimeSat May 16, 2015 7:08 am
I'd go with Dave & Sim's diagnosis - main fuse
PostSubject: Re: MOT Fail. Dead Relay? No Power   MOT Fail. Dead Relay? No Power Icon_minitimeSat May 16, 2015 10:48 am
Symptoms suggest main fuse has gone - but that does not identify the 'problem' ... is you have doubts about the relay, then that could be the clue - you need to check anything you have recently changed to see if there is either a faulty component causing a short, or some poor wiring.
PostSubject: Re: MOT Fail. Dead Relay? No Power   MOT Fail. Dead Relay? No Power Icon_minitimeSat May 16, 2015 12:19 pm
I had a very similar thing happen when I was re-wiring my rear.  You'll find that it's popped the main fuse.  If you've just changed the indicators, I'd hazard a guess that somewhere you have a wire touching either part of the frame or shorting across to another wire.  I'd start by buying a handful of mini-spade main fuses (30amp?), then try it & see if it works - chances are, it's blown the relay.  I wouldn't put the old relay back on till you've disconnected the cables from the new indicators.  I'd check the routing of the cables to see if they're touching anywhere.  If I couldn't see anything obvious, I'd then re-connect the indicators, one at a time & see if any of them blow the fuse again.  But I'd certainly initially go with the indicator theory
» LED Flasher relay problem?
» Starting problems/Relay?
» Fitting a relay for heated grips.
» Starter Control Relay
» Where is the flasher relay located?
MOT Fail. Dead Relay? No Power Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
MOT Fail. Dead Relay? No Power Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
MOT Fail. Dead Relay? No Power Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
MOT Fail. Dead Relay? No Power Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
MOT Fail. Dead Relay? No Power Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
MOT Fail. Dead Relay? No Power Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
MOT Fail. Dead Relay? No Power Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
MOT Fail. Dead Relay? No Power Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
MOT Fail. Dead Relay? No Power Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
MOT Fail. Dead Relay? No Power Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
MOT Fail. Dead Relay? No Power Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
MOT Fail. Dead Relay? No Power Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
MOT Fail. Dead Relay? No Power Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
MOT Fail. Dead Relay? No Power Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
MOT Fail. Dead Relay? No Power Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
MOT Fail. Dead Relay? No Power Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
MOT Fail. Dead Relay? No Power Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
MOT Fail. Dead Relay? No Power Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
MOT Fail. Dead Relay? No Power Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
MOT Fail. Dead Relay? No Power Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
