 Just visiting for final drive info...
CS_0427
Just visiting for final drive info... Empty
PostSubject: Just visiting for final drive info...   Just visiting for final drive info... Icon_minitimeSat Feb 03, 2024 11:25 pm
I have a 90's model GSX1100G and am considering converting it to electric drive. Since it's a shaft drive, an issue I have is the low (number) final drive at 2.66. I want to see if there is a much higher numerical drive I can use with rear wheel or otherwise adapt. The parts listings I've found say many are 34 ring / 11 pinion teeth for 3.09:1 (my G is 32/12 for 2.66), but ideally I'd like to be around 4:1.
Since I'm new, I can't reply to posts, but I saw this one regarding final drives from 2021 and want to follow up on this:
to clarify something from above if you ask Suzuki what the final drive ratio is for the vs 800 and vs 1400  they will tell you its 3.09 :1 and 2.66:1 respectively ( i think, i haven't got that info at hand at the moment) but i know from the bench test that the vs800 is a shade over 4:1 when only involving the shaft to wheel ratio.
CS_0427
PostSubject: Re: Just visiting for final drive info...   Just visiting for final drive info... Icon_minitimeSun Feb 04, 2024 10:17 pm
So as near as I can tell, the 4:1 claim is incorrect. The secondary drive on that bike is 1.133, which makes the actual 3.09 final drive around 3.50 (which Suzuki still claims for the 2023 C50).
Just visiting for final drive info... Vx800_10
At this point, I'm still looking for a higher numerical ratio drive I can adapt for my needs. One other possibility is to have a custom pinion made for my drive. 8 vs 12 teeth would give me exactly 4:1 with my 32 tooth ring gear.
CS_0427
PostSubject: Re: Just visiting for final drive info...   Just visiting for final drive info... Icon_minitimeTue Feb 06, 2024 2:28 am
I found a VX800 final drive for sale on eBay and messaged the seller asking them to check the ratio. He said for every 3 turns of the driveshaft the hub made 1 turn, so it's about a 3:1 ratio. I found the Yamaha FJR1300 has a 3.67:1 ratio so that may be my best bet if I can adapt the rear wheel from one.
» Final drive
» vs 700 final drive - does this fit into VX 800 ?
» vs 1400 final drive in a vs 800
» SAE90 final drive oil?
» VX800 final drive
Just visiting for final drive info... Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Just visiting for final drive info... Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Just visiting for final drive info... Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Just visiting for final drive info... Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Just visiting for final drive info... Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Just visiting for final drive info... Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Just visiting for final drive info... Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Just visiting for final drive info... Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Just visiting for final drive info... Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Just visiting for final drive info... Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Just visiting for final drive info... Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Just visiting for final drive info... Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Just visiting for final drive info... Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Just visiting for final drive info... Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Just visiting for final drive info... Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Just visiting for final drive info... Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Just visiting for final drive info... Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Just visiting for final drive info... Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Just visiting for final drive info... Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Just visiting for final drive info... Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
